Question about HP Televison & Video
How to program a hp 9500 tv universal remote - HP Televison & Video
Posted by Charles Wayne Browne on
5 Related Answers
Anonymous
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
Anonymous
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
Anonymous
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
Anonymous
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
Anonymous
SOURCE: Need code to program universal remote for my Apex LCD TV
i have apex tv 2003 and i need a code for my remote
Posted on Jun 02, 2010
Samsung remote HP-T4254 need code please
If you need the code list for the original HP-T4254 remote, BN59-00599A, these are listed in the manual starting at page 22. The steps to program the remote are on the preceding page. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-TYaga4aDv9F/p_305HPT4254/Samsung-HP-T4254.html . The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20071022131600/Manuals/305/305HPT4254.PDF .
Please note that the codes programmed into the remote will probably not operate devices that are newer than the TV. Sometimes electronic devices that were released less than 6 months before the remote was programmed will not respond to the available codes in the given remote.
If you are trying to find a Samsung TV code that will work with another remote, please indicate which universal remote you are trying to program. (There is a Redi-Remote replacement for the BN59-00599A that does not function as a universal remote.)
I hope this helps.
Sep 18, 2016 | Samsung HP-T4254 42 in. Plasma Television
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    What is universal remote code for bd-2000 on rcrno4gr remote
    Remote code for HP BD-2000 Blu-ray player - AT&T Community
    https://forums.att.com/.../Remote.../Remote-code...BD-2000.../467...
    AT&TDec 2, 2012 - I have an HP BD-2000 Blu-ray player that I recently lost the remotecontrol for. I do not see HP as a manufacturer on the DVD list when I try.
    Universal Remote Control Codes List - TV SAT DVR ...
    removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
    Nov 10, 2013 - We compiled this universal remote programming code list to make it ..... Looking for a code for a orion vcr I have a 5 digit universal remote by rca -rcrn04gr and I ... remote control code (s) for a samsung blu ray dvd player bd-fm51 /ZA ... Please, could someone to give me the code for DENON AVR-X2000.
    Programming the RCA RCRN04GR Universal Remote
    voxrightnow.custhelp.com/.../programming-the-rca-rcrn04gr-universal-r...
    Jul 28, 2010 - Program your Remote. To use this universal remote with your home entertainment system, first you need to program it to control your devices.
    [PDF]Rcrn04gr - Universal Remote Control Codes
    Jan 19, 2016 | HP bd-2000 blu-ray player with 1080p...
    Code for programming to a LG 4K tv?
    1. LG UHD 4K Television - LG.com‎
      Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
    Search Results
      Find Your Comcast Remote Control Programming Code
      customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
      Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
      DIRECTV - Remote Control Code Lookup
    Jan 01, 2016 | LG Televison & Video
    What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
    How To Program A Philips Universal Remote ' Codes For ...
    codesforuniversalremotes.com/program-philips-universal-remote/
    Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
    Codes For Universal Remotes ' Universal Remote Control ...
    Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
    Dec 28, 2015 | Philips Televison & Video
    NH305UD. How can I program it?
    Universal Remote Control Codes - Emerson Instructions
    www.remotecodelist.com/remotes/emerson/emerson.html
    Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For ... Emerson multi-brand remote codes for tv's.
    Remote Control Codes For Emerson TVs ' Codes For ...
    codesforuniversalremotes.com/universal-remote-control-codes-emerson-t...
    2 & 4 Digit Universal Remote Control Codes For Emerson TVs Emerson multi-brand remote ... How to Program a Universal Remote Control : Universal RemoteProgramming of TV ... Can you give me the code for Western digital TV box please.
    Emerson brand TV remote codes - Comcast Help and Support Forums
    forums.xfinity.com/t5/XfinityTV-and.../Emerson...TV-remote.../784589
    May 22, 2010 - I have a Emerson TV model # BLC320EM9 A and I cannot find a ...http://www.bing.com/shopping/logitech-harmony-300-universal-remote-control/p/7E7752820C88A8C05005?q=. ..... I can not get 11864 to work with the silver xfinity remote that has the ..... Code 11864 was not listed in the program guide.
    Dec 25, 2015 | Emerson Televison & Video
    How do I program it to a Magnavox tv flatscreen
    Programming an RCA Universal Remote - YouTube
    ? 2:46
    https://www.youtube.com/watch?v=MZd4yBivcZ4
    Nov 10, 2008 - Uploaded by alpharedecho
    ... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
    Magnavox TV codes - Magnavox TV set. Buy, reviews ...
    magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
    Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
    RCA Universal Remote Control- Target Programming ...
    Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
    I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
    Find codes and methods here.
    http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
    If those codes dont work try the last three(or four) numbers of your TV's serial number.
    On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
    Oct 08, 2010 | Universal Remote Control Universal IR...
    Cannot find remote code for panasonic TV/VCR combo for RCA remote
    Here is a list of codes for your remote. Please follow any of the links below to get your codes.
    Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
    Search Results
    1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
      www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
    2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
      www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
    3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
      www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
    May 05, 2009 | RCA Universal Remote 3 Device Remote...
    Televison & Video Logo
    398 people viewed this question
    Top HP Televison & Video Experts
    RockTheHood
    Stan Ford
    Are you a HP Televison and Video Expert? Answer questions, earn points and help others
