Toys Logo
e
edwardsmith Posted on Jan 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New brite silver rail express
Where is battery compartment
Simon Flummox
Level 2:
Novelist:
  • Expert 91 Answers
  • Posted on Jan 07, 2018
Simon Flummox
Expert
Level 2:
Novelist:
Answers
91
Questions
0
Helped
61575
Points
431
For battery powered New Bright train sets, remove the "coal" from the tender car (behind the locomotive) to insert batteries.
Note that some sets draw power through the wheels, from a wall adapter that clips to the rails.
Tony Parsons
Level 3:
  • Master 6,405 Answers
  • Posted on Jan 06, 2018
Tony Parsons
Master
Level 3:
Answers
6405
Questions
Helped
1651869
Points
20272
I can find no camera with this description - please can you tell us the make and model ?
1 Related Answer
Anonymous
  • 7191 Answers
  • Posted on Dec 21, 2010
SOURCE: new instructions for new brite
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Does anyone know where the batteries go in a 1992 Toy State Nutcracker Express Train engine?
Does it use batteries or is it picking up current from the rails and a supply transformer?
Where is the fuel filter located on a 2004 Chevy Express van
Hello Shawn,
Check your left hand frame rail.
On 2005 gasoline engines the fuel filter is integral with the fuel pump/sender assembly in the fuel tank.
The fuel filter is normally located along the frame rail of the vehicle. On some vehicles however, it may have been relocated to the engine compartment. When in doubt, trace a fuel line from the engine backward or from the tank forward in order to locate the filter.
Some vehicles utilize a spin-on fuel filter located on the frame rail. This filter can be turned counterclockwise after the fuel pressure is relieved.
Camera will not power on. has new batteries. inside battery compartment middle contact is a little discolored. rest are silver it is brown. looks like a little moister has gotten in there
try to scrape the dark residue of with a wooden tool that is long enough to reach the discolored button as long as there is small bit of silver showing the current will get through .
Where is the low side ac port on a 2005 3500 van,? side of the silver can or hidden
on reservoir tank or a/c drier tank on right side in the engine compartment is a silver tank
I have an 1985-1986 talking silver rail express train set and it will move just a little ways and then stop. Has something happened with in the gear system?
My son recently disassembled one with the same symptom. He found one of the small gears in the drivetrain had split -- causing it to bind and limit motion to a inch or so. It's been in the family 25 years, but we elected to junk the locomotive :(
Nov 09, 2013 • Echo Toys
1helpful
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
1helpful
Gas leaking from a silver metal tube in engine next to throttle.
You need to have this repaired immediately. It's not too expensive, just an o-ring at the end that goes into the fuel rail. It is very dangerous to have fuel leaking in the engine compartment, don't delay.
1helpful
99 chevy express van 5.7 wont start after sitting for a day. fuel pump is new,it has spark,and no codes.
A new fuel pump can go bad but you need to know if the fuel rail has pressure or fuel in it the next day. Take something and press on the shradder valve on th fuel rail and see if you have any fuel. If not the fuel pump may be installed wrong.The fuel rail should have some pressure all the time for quick start up. I do not know if this helps but it is a start.
4helpful
Train powers up,lights go go.Press forward and it just buzzes.Doesn't move. New Bright said it's the 'Tender Car ".
The tender car supplies power from the track to the entire trian.
Make sure the train will run with just the Loco and the tender. Make sure the tender is securely plugged in to the Loco and make sure the the brushes under the wheels on the tender (this is how power gets from the track to the train) are in contact with the track. Finally use a scotch brite pad (DO NOT USE STEEL WOOL) to clean up the track a little.
You can also take a volt meter and measure for DC between the rails. You should have about 10.5VDC on the track. (Inside rail is neg on mine and outside is pos) ...
Hope this helps..
Bob
2answers
2009 Chevrolet Express Van Hot Wire
sorry but there are no hot always wires at the rear of the van.there should be a hot near the battery at a junction connector .
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
