Question about Bosch Televison & Video
Hello. I have a Bosch Maxx6 WAE 28140 washing machine with an error at the moment. 1400, 800, 600 and rinse stop lamp are blinking. Can you please tell me what error code it tells me?
Posted by peter van der Veeken on
5 Related Answers
Anonymous
SOURCE: code error f07 indesit washihg machine
Per Maytag, they suggest you unplug the washer for 20 minutes and see if that resets the circuit board.
Posted on Feb 27, 2008
Anonymous
  • 33 Answers
SOURCE: Audio sound your problem
The fist thing to try is uninstalling and reinstalling winamp. (Add/remove programs, select winamp and click unintall) That will most likely fix it. Othewise http://forums.winamp.com/showthread.php?postid=1617490#post1617490 says
" 1. Winamp > Ctrl+P (for preferences)
2. Plug-ins > Output
3. double click 'DirectSound output'
4. Driver tab
5. make sure the device in the drop-down list correctly reflects your soundcard
-and/or-
1. Control Panel
2. Sounds & Audio Devices icon (or MultiMedia Icon)
3. Audio tab
4. in 'Sound playback' make sure the 'Default device:' drop-down box correctly reflects your soundcard"
Posted on Apr 01, 2008
alvinbga
Alvin Barnabas
  • 136 Answers
SOURCE: the power lamp is blinking orange
Make sure it is plugged into a computer with a working video card. If error code is still there you have a main board problem. Who is the manufactorer?
Posted on Jun 30, 2008
Anonymous
SOURCE: error code tricity bendix aw1200w washing machine
I think this is a problem with the thermister (built in to the heating element assembly).
Posted on Jul 27, 2008
Anonymous
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
If a bosch washing machine is indicating 0 on the display panel.how do we resolve the problem
Unknown what model it is - you can use the comment menu to give more information about your problem.
Possibly a child lock was set according to the Bosch WAE Range Washing Machine link below:
https://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Why won't it heat up? And what does error code 311 mean
rcr311w codes Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > rcr311w codes
Zita http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes.html here is one link to error .
Bosch Maxx6 washing machine. Shut door,rinse button flashing but door not lock so start button will not start circle
look at the place where the lock locked in the door the metal pinns could be broken or covered with erosion or something. De door lock makes no contact with the receptor.
1helpful
Bosch WAQ24461SN Error code E35. Help please. Zita
here is one link to error codes not waq series but will give you an idea
here is a link to a nice little video how to make a good guess whats up and also the error code info you need
usually you find high up codes are something to do with sensors or flow rates on intake etc
sorry cant find the exact error condition you have
a quick phonecall to bosh service department and they can tell you they are very helpfull as a company
http://www.espares.co.uk/advice/0/2593/how-to-identify-an-error-code-on-a-bosch-neff-or-siemens-washing-machine-
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
Washing machine stopped and door opened and says E3. please help. machine is a bosch wae....
The machine identifies and indicates some operational errors through a series of beeps.E3 is also listed in that beep.the meaning of e3 is nothing but it is telling to call the service engineer.This error signal is due to Thermistor open/short.Thanks for your question.
7helpful
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Televison & Video Logo
Top Bosch Televison & Video Experts
Steve Pack
Steve Pack
Larry
Are you a Bosch Televison and Video Expert? Answer questions, earn points and help others
