Question about Radio Shack Measuring Tools & Sensors
Need instructions for radio shack weather forecaster 63-1090
Posted by Bill Tschida on
3 Related Answers
taran_2005
taran_2005
  • 10515 Answers
SOURCE: I need an owners manual
Download the instructions from :-
http://support.radioshack.com/manuals/ome63-1090.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 18, 2011
mbhome
  • 32 Answers
SOURCE: How to set radio shack weather forecaster to accurate time zone
http://support.radioshack.com/manuals/ome63-1085.pdf
Posted on Nov 01, 2012
Dennis Engelking
  • 643 Answers
SOURCE: Need Radio Shack weather radio Cat. No 12-521 manual
Step 1:
CHECK OP (Check Operation) means your radio has not received any type of
SAME alert signal (include test or demo signals) for about 10 days.
Make sure the antenna is fully extended and the stored location is correct. See
"Programming Locations and SAME Codes" on page 9 for more information.
Step 2:
Here is a link to the manual
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1200521_PM_EN.pdf
Posted on Dec 06, 2012
I have high temperature of 101.9 I'm not home what do you recommend
take some rest and when you feel sick, call or visit a doctor.
Mar 09, 2014 | Radio Shack RadioShack Professional...
Displays just lines on outside display and has displyed HHH on both displyas , inside temp is fine
HHH means the temp is over the range that was designed. Where did you locate the sending unit?
Mar 11, 2013 | Radio Shack Wireless IndoorOutdoor...
Can I replace the sensor for a Radio Shack 63-1090?
I presume by sensor you mean the remote sensor not the main unit which also has sensors? When you buy the 1090 you get one external/remote sensor which is also labeled 1090. If you buy extra sensors they are 1092's. Another new 1092 sensor should work with your 1090 it does on mine. You can have up to 3 remotes just set the channel on them. Getting one is the problem. If your talking of stripping the box down to replace the sensor , well I am sure more than the sensor would have a fault!
Oct 29, 2012 | Radio Shack Wireless Weather Forecaster
How do I reset my 63-1090 Clock
how do i set up my 63-1090 clock need instructions thank bobby woodberry
Jun 20, 2012 | Radio Shack Wireless Weather Forecaster
How do you replace the batteries in model 63-1090? I can't get the back cover off.
Below is a copy of the owners manual for the device you are inquiring about. This will show you how to replace the batteries.
May 31, 2011 | Radio Shack IndoorOutdoor Thermometer with...
Radio Shack thermo hygro sensor model 63-1090 reads everything except the outside temp
I ran into this problem and note that in the manual is states for "best results" the sensor should be powered up before the station. I had the station running and it wouldn't lock even after several hours. When I powered it down and brought it back up, it saw the sensor just fine...
Jan 15, 2011 | Radio Shack IndoorOutdoor Thermometer with...
Measuring Tools & Sensors Logo
413 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
