16 y/o top load kleenmaid w/mach does everything except agitate.some time will not spin (I think until motor cools)lid switch fine.maybe needs new drive or motor .belt is good & tension is fine
Posted by Frank Riches on
Tom Chichester
    Top Expert:
  • Washing Mach... Master
  • 56,001 Answers
Your 16 y/o Kleenmaid is getting elderly and repair may not be economical.
Posted on Jan 05, 2018
Chris Huff
    Top Expert:
  • 6,289 Answers
Sounds like motor is going bad if it has to cool before working again.
Posted on Oct 02, 2018
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Posted on Aug 29, 2007
Anonymous
  • 146 Answers
SOURCE: washer not spinning
Sounds like the brake liner could be broken. When the machine starts to spin, the motor turns in the opposite direction to the wash cycle and causes the bowl to lift off the brake liner and the bowl then spins freely. Either the riser cam is worn/broken or the brake liner is broken. This is quite involved and you may have to call in a tech.
Posted on Nov 04, 2007
vest6
Elmer Vest
  • 196 Answers
SOURCE: Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Posted on Jan 13, 2008
Jaime Hernandez
  • 2337 Answers
SOURCE: Whirlpool Top Load washing machine no spin cycle
Click here for more info on the direct drive appliances.
Posted on Aug 28, 2008
Anonymous
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
Won't aggitate but will spin
the lid switch could cause this problem as well as the timer.i do not think you need to replaced the agitater at this time
Sep 16, 2009 | GE WDSR2080D Top Load Washer
Whirlpool LSR8233eq top load washer won't spin most of time
Hi, It sounds like your spin basket drive is going bad. Even tho you cleaned the brake, the pads get worn down enough they will not grab. The only other thing I can think of is the bloch that sits on top the basket drive shaft and lockes the inner tub. Sounds like you have done/checked everything else.
Please let me know if I can assist you further.
Vic
Jun 20, 2009 | Whirlpool LBR4121JQ Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Agitate/Spin Issues (again)
if your coupler is good change your agitator dogs that will fix slow wash and clutch on top of transmission or lid switch for no spin
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
LSR7233DQ1
check your lid switch, it can be bypassed until you can get a new one. Just be aware that the machine will agitate and spin with the lid up. To open the top use a putty knife or butter knife at the joint of the top and bottom at the front corners to push the catch in while lifting the top. On an older machine the lid switch goes bad, another thing is the rubber drive part between the motor and the transmission, but the machine probably wouldn't agitate either.
Jul 27, 2008 | Whirlpool LSR7333 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Dec 03, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Could I please get a follow-up to this previous issue? I just had one more question, posted on the 30th of October. Thank you!
ok i might have to put this in a 2 part solution it might not be big enough to fit here
i hope this helped you in your washer it still is cheaper to repair than to replace
your washer blew out its thrust bearing which is called the brake
while you have the washer open grease the bearings and oil the motor you can get these same things and intstructions for this to do
this is the thrust bearing kit which you will need the instructions i will post the link and a copy of the pic
http://www.appliancepartspros.com/part_details.aspx?part_id=3728465&pn_=12500036
this is the link to the thrust bearing kit you need to replace to run dryer correctly
5953465.jpg http://www.applianceaid.com/images/thrust_kit_remove.jpgthis are the instructions for thrust kit
Nov 01, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
571 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
