Question about RCA RC5220P DVD Player
Has stopped playing
In mid movie it started jumping - skipping -Like a bad Sat signal. At first I could reverse and replay the section that was skipped. Then it got worse and it would freeze, only control that worked was stop. Now error message saying "An error has occurred. Turn the power on and back on if the problem persists consult the owners manual.” It did – manual was no help.
Posted by Dmax on
  • Anonymous Jan 24, 2009
    DVDS STOP FREEZE OR BREAK UP NO SCRATCHES ON DISCS. WHAT CAN BE DONE? CLEANIING?
Anonymous
    Novelist:
    Champion:
  • 244 Answers
Skipping
Remove and replace the graphite grease from the laser transport worm gear assembly (use the correct Technics stuff), replace the worm gear drive belt, and ensure that the tension spring on the C-shaped plastic piece that rides the gear is OK
Posted on Nov 24, 2007
1 Related Answer
Anonymous
  • 244 Answers
SOURCE: Error Message
Skipping
I recorded an event but when I recorded an event but when I replay it the little cassette jumps or skips. What is causing this to happen?
standard play" (SP) quality. Other speeds include "long play" (LP), and "extended play" (EP) or "super long play" (SLP)
https://en.wikipedia.org/wiki/VHS
mismatch of recorded vhs speed to play back speed could be cause
4answers
1helpful
3answers
Ps3 skips while playing dvd
Get a dvd cleaner cd from walmart or target that is made for blu ray's and that will help you out a lot, if you have a console like mine where the top opens and you can access the dvd and see the eyes if the laser, take a q-tip with some isoproyl alcohol and clean both eyes off, but make sure the q-tip is not overly soaked since you don't want the extra liquid dripping into the console!
My sylvania sdvd6655-B skips and then stops playing. What can I do to fix it?
first time turning it on and all see is mod: not sopported
I have a model nsx 3150 and the cds skip a lot
Hi,what makes the nsx 3150 skipping, is because the Lens inside the DVD section that makes a DVD plate play when inserted is weak and needs to be replaced.
When a Lens is weak,it will not allow you to watch a full movie or play a CD properly. Might stop on the way or skip
What to do is this, you will need to clean the Lens with a DVD lens cleaner.You can buy from Online stores and it comes with instructions..
But note after cleaning the DVD lens, if still does the same way,that means you will have to replace the Lens inside the DVD player section.
To replace the Lens, contact the nearest repair store or outlet around your area..
Take care..
Lg dvd player stops or skips plaing dvd movies
These unit have a problem with the complete assy.mech needs to be replaced if cleaning does not take care of the problem
When i play movies on line i can here sound and see the movie but it skips and stop
When you use videos or music online the program you are using allow space for them to use…your program may not giving them space that they can load the file to and then played for you, to fix this you need to give them more space when you start any movie right click on the screen and you will get a small window asking you for information click on the sound section and give more space, and do same with other setting and see how this work....let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
I have the philips 120hz and some movies are smooth, others jump
I would advise knocking down the resolution. Try and use software, like red kawa, to convert a few of your movies to different formats till you find a decent one. A widely accepted codec setup is Divx/XVid (both are the same) and MP3 sound.
2helpful
The discs keeps skipping and stopping like the old movie reels
DVD will play and all of a sudden will stop right if the middle of a movie
Error Message
Skipping
RCA RC5220P DVD Player Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
