Question about The Office Equipment & Supplies
The drive gear near the shredder mechanism is missing two teeth. it is a mode spl-txc152A. Anywhere i can purchase this part.
Posted by diego galindo on
ray gallant
    Top Expert:
  • The Master
  • 68,569 Answers
You can not as no one make replacement nylon gears
Posted on Jan 07, 2018
3 Related Answers
Anonymous
  • 35 Answers
SOURCE: Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Posted on Feb 23, 2009
Anonymous
SOURCE: My Xerox XRX-8X paper shredder
WHERE DO I GET A DRIVE GEAR FOR MY XRX-8X PAPER SHREADER CHEAP.
Posted on Sep 03, 2009
Bill Boyd
  • 53814 Answers
SOURCE: I have a Staples SPL-TXC152A shredder. I need two gears: the big plastic one and the large metallic black one. Badly stripped!
if you can get them from the manufacturer spares , the cost may exceed a new unit
Posted on Jun 14, 2016
I recently bought a Staples Shredder Model #SPL-TXC152A & has worked fine up until now. I emptied the bin as I have previously & bow shredder will not turn on.
There is a bin interlock switch that has to be closed for the shredder to shred. If the shredder mechanism is separate, look for a slot on the underside.
Apr 13, 2018 | Staples Office Equipment & Supplies
My shredder has the sound like it is working, but it is not shredding.
From your description, it sounds like when you insert the paper the motor turns on, but the paper is not pulled into the shredder, indicating the two shredder cylinders are not turning. The most likely cause of this is a stripped (missing teeth) main nylon gear. These can be replaced but require some effort.
Apr 17, 2014 | Royal Office Equipment & Supplies
Staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Jun 16, 2009 | Office Equipment & Supplies
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Jan 19, 2009 | Intimus 385 se Shredder
51 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
