Question about Sharp Televison & Video
Hi i have a sharp LC-55CUF8472ES tv and when i bought it it could play dts sound from movies from my hard drive.i updated the firmware and now it doesnt play any sound from dts movies.Any help please?
    Sergeant:
  • Sharp Expert
  • 258 Answers
You can try Leawo Blu-ray Player which is actually can be used as a simple audio player that can play DTS audio in lossless quality. It can also many other audio effects such as TrueHD and Atmos with support up to 7 audio channels. it can also capable of playing videos from DVD discs, from ISO images, from local disc folders, and from local standalone multimedia files as well.
Posted on Feb 21, 2020
  • Sharp Master
  • 5,699 Answers
Try looking at the sound settings. It might have switched them back to normal, instead of DTS.
Posted on Jan 04, 2018
Testimonial: "i have tried everything from the menu options but no luck."
  • 1 more comment
  • panos
    panos Jan 05, 2018
    i have tried everything from the menu but with no luck.
    I have done all the frimware updates(3)with the last one from december 2017 but again nothing changed.
    What else can i do?
  •  Grubhead
    Grubhead Jan 06, 2018
    Have a word with Sharp, since it was working before the update. They might have a fix for it.
  • panos
    panos Jan 07, 2018
    thanks a lot!
3 Suggested Answers
satavlad
Alex Zoubkov
  • 405 Answers
SOURCE: Wrong firmware updated to my Sharp HP20
There is new firmware avalable, try to load right one.
Posted on Oct 26, 2009
Anonymous
SOURCE: need to find software update for sharp blu ray
my sharp aquos will not play certaian blue ray I've exchanged the the disk a couple of time...are there any updates that I need
Posted on Mar 07, 2010
VinnyIRL
  • 15 Answers
SOURCE: HELLO,JUST I NEED TO THE
Here ya go:
  1. Download the latest firmware HERE
  2. Format a USB memory stick to FAT16
  3. Copy the contentse of the firmware zip file to the root of the USB memory stick (Root is the first view you see when you open the drive)
  4. Plug the drive into the TV
  5. Go through the TV menu and find the update firmware option
  6. Pray the power doesnt go out
Posted on May 09, 2011
Hi! I have a new tv sharp LC-55CUF8472ES and is stuck in headphone mode! I try to move it in headphone and tv and did't work. please help!
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.//
Oct 07, 2017 | Sharp Televison & Video
How do I update the firmware on my sharp lc-37rd2e I have a problem with hdmi on wii cosole I am currently on version 1.04
Get the update from Sharps website. Load it on an EMPTY formatted usb thumb drive. From he setup menu on the TV select software update.
Dec 29, 2014 | Sharp LC-32SB24U 32 in. LCD TV
Movie stops
Generally speaking....the Sharp Blu-ray is working just fine. The problem is you are not using commercially made programs or movies that are universal and burned for use in a standard player. When a COPY of a Movie is made on a home burner; the speed and other factors may not be consistent with commercial values. In lieu of a BR disc.; try using a USB Thumb Drive in your TV or Computer. Just go to Torrenting . com for free movies; download your selections, and copy the data to the USB drive. Then put the USB drive into the Computer or TV and enjoy. It is cheaper than burning a disc and you can erase the USB device and use it over and over again. Good luck the BentonComputerDoctor at Hotmail.
Dec 18, 2013 | Sharp Televison & Video
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf .
I wish that I had better news for you.
Jun 04, 2017 | Sharp LC-32SB24U 32 in. LCD TV
HELLO,JUST I NEED TO THE FIRMWARE FOR MY TV SHARP LC-32D44U.HOW I CAN GET IT THE FIRMWARE? THANK YOU.
Here ya go:
May 09, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Feb 08, 2010 | Sharp LC-32D64U LCD TV
My western digital media player have no audio when playing movie with dts sound
Use a program like MKVMERGE GUI to convert the DTS track into AC3 or PCM before using on WD player.
Jan 15, 2010 | Western Digital TV HD Media Player USB...
I ripped Bluray movies using "ANY DVD HD" to my hardrive then playing them through "WD TV Live HD Media Player" (using HDMI cable to Sony Bravia HD L.C.D.TV) some movies work good but others play the video...
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
Nov 30, 2009 | Western Digital TV HD Media Player USB...
My Sharp LC-26D6U TV - low audio
Sharp is taking care of this for customers even if you are out of warranty due to a mistake on how they made the tv. All you have to do is call Sharp at 1-800-237-4277. Please make sure that the repair shop also applies 2 firmware updates that all the D6U tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. Good luck!
Sep 28, 2009 | Sharp LC-26D6U 26 in. LCD Television
Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck [email protected]
Dec 27, 2008 | Sharp AQUOS Blu-ray Disc Player
Televison & Video Logo
319 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
