Cameras Logo
Question about Toshiba Cameras
I'm getting error message E 4 54039000 although I'm using a new disc of the kind I've always used. Toshiba rdxv59dtkb2
Posted by Jackie Taylor on
5 Related Answers
Anonymous
SOURCE: will not run
I had the same problem with my machine, there is nothing you personally can do to fix it. You'll have to find a service tech who can work on it to solve the problem.
Posted on Jan 06, 2008
Anonymous
  • 338 Answers
SOURCE: Toshiba Recovery Disc Creator isn't working
hello lazerr_man,
Try to use another freeware burnprogram like burnatonce to create an
other CD, just to check if the Combo-drive is writing properly.
If you don't get any error messages like the ones from Toshiba program, then the problem is the toshiba software.
If other burn programs find difficulties in accessing CDs or DVD-Rs
then the drive itself giving you a hard time and might seek for replacement.
You may find the toshiba exchange parts too expensive and the internal drive is still reading disks properly, then think about an external dvd-rw drive, but make sure to buy a highspeed USB one (or even firewire, if the laptop has the port), else it will run rather slowly.
good luck
Posted on Sep 07, 2009
Anonymous
  • 3006 Answers
SOURCE: Can this Olympus C5050Z works with Sandisk CF
Your camera was designed to be fully CF compliant, but it was designed long before 4GB cards were available so your problem is likely to be that the camera cannot handle a card of that large a capacity.
I've checked the Olympus servicing manual but unfortunately it doesn't state a maximum CF capacity and there have been no relevant firmware updates to extend CF compatibility.
When your camera was released back in 2003 the largest capacity CF card was 1GB so I suggest that you don't go above that size. You'll also be wasting your money on any more than a regular Sandisk Ultra as the camera cannot take advantage of the faster data transfer rates of later cards, I'm not even certain that it can utilise the speed advantage of an Ultra over a really basic model, but it won't cause the camera to throw it's toys out of the pram either.
I hope that you've found my reply to be of use and ask in return only that you return the goodwill and rate my answer.
Posted on Nov 23, 2009
Rider On Way
ONE-Touch-Solution
  • 1679 Answers
SOURCE: i have the same problem the toshiba recovery disk
You have tried all possible solutions and troubleshooting.
My Suggestion is to check the Warranty of the Hard Disk and get it replaced. this possible shows a mismatch between the Laptop and hard drive.
Posted on Feb 15, 2011
SOURCE: Getting a C 13 70 disc is dirty message only for
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Nov 03, 2011
Model RDXV59DTKB2 HDD/VCR. On HDD playback it has started,after varying periods of time, to freeze the picture. It can only be restarted by using FF and then Play.
You should be talking to Toshiba support, It could be a bad hard drive having trouble with sectors lost and access. Same as in computers. The way to eliminate hard drive errors is to do a low level format but that just maps the bad sectors into the bad sector table. When the drive starts to fail like this then it is time to not try and fix it as it will continue on this path as the errors migrate across the media disc but to replace it. Low level format is just putting off the failure until the errors become too many to deal with. Probably a Seagate drive- you don't buy them you only rent them for a small time. I stopped buying then at all. Made in China is all you need to know.
2answers
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Good luck.
I have the same problem the toshiba recovery disk i get error message 10f8060017.its a toshiba A105-2194 win xp media edition. i have tried everything wiped the disk to all 0's. Used a win xp original disc...
I have a d-r2sc toshiba dvd recorder that will not recognize a dvd-r 4.7 gb version 2.1 disc. I get an error message saying "Check disk. May be damaged or may require cleaning". I have tried...
I've got it!!!!!!!
Although this is an old thread, recently I had an idea about my own Toshiba DVD Recorder. Same problem all over the grid when it comes to this model and hopefully some of you who currently have this problem will find my post and once again be using your unit as I am mine. The problem is so simple you'll flip! This Toshiba DVD Recorder device is exactly what we're all using as DVD burners in our home pcs, just a Toshiba in this one though, I had an LG multi-writer, dula layer, blah blah blah and when I opened up my Toshiba unit, saw how the screws go into the sides, the IDE connector is EXACTLY what we will find in our PC's, the Toshiba jumper pin was set to MASTER and like modern day DVD or CD drives, we no longer need to connect an audio connector to get what else, but audio.
Early today I looked closely at my LG replacement unit, saw that the tray is more shallow than the original Toshiba one. Most of you know why the tray is so deep? Because with this unit one can use the cartridge-style DVD-RAM disc but since a PC's dvd tray is not as deep, I just ripped into the case and used the actual ram disc without it. The Software Version for the Toshiba is ZN10 and the DVD Drive Software WAS 1309. The drive software will change to whatever your newest PC-DVD recorder will be. In my case I had a 2006 LG and the Toshiba was a 2004 but irrelevant anyway. One thing you must remove from a PC type DVD recorder/burner, is the front access door and the surrounding trim since inside the Toshiba home unit, no door or trim attached to the Toshiba's DVD unit but of course you would notice that the silver door opens when the eject mech. is actuated.
For 2 years my Toshiba was malfunctioning, would read older discs I had recorded and finalized, some of the other discs I had recorded some things on but didn't finalize, I was able to do so today. The problem I have heard about these Toshibas is that their laser units are el cheapo but kind of ticked me off because we paid $550 in 2004 for this thing and no hard drive of course. I do have an issue with my clock on this thing and maybe because we had it plugged in for the past 8 years or so. When off, nothing on the display, when turned on the display shows the time and then it blanks out and we can only see the elapsed time, counter etc. Not that it matters but don't think I'd ever buy another Toshiba device anyway now.
Hope this has helped and trust me here, if your unit still powers on and you keep seeing the disc read error etc., you can probably find yourself a brand new dvd recorder for about 30 bucks retail and problem solved. Oh yeah, one interesting note and if I hadn't mentioned this now, some of you would realize it anyway, this unit will now record + and - since it's actually a PC recorder device LOL. Stupid Toshiba made this as only one type and that was -R but for the life of me, can't figure out why it couldn't have been both/all types. Really have to add about what I was reading awhile back too, some were advising that one couldn't use -RW types (rewriteables) but the issue actually stems from the laser and unit's weakness at reading better quality discs. The ones I had copied and finalized as WRITE ONCE (only) were really cheap ones and they have always worked. Prior to doing this unit swap I tried a store bought movie and it wouldn't read it at all, then when I did the hardware change, VOILA!
Ref. Toshiba VCR, model RDXV59DTKB2 I copy ,using the dubbing function, of VHS to DVD. The disc then works in this and most other VCR's but will not playback in my PC nor my portable DVD player....
Check if your DVD drive in your computor is the same type as your recorder. IE A DVD + or DVD -.
Some types of drive will not play the others. You might need to upgade your drive in your computer to one that will play nearly all formats.
1helpful
2answers
hello lazerr_man,
good luck
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
2helpful
2answers
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
Toshiba D-R2su Recording Error
I've got it!!!!!!!
Will not run
Top Toshiba Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
ADMIN Eric
ADMIN Eric
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
