Question about Casio Office Equipment & Supplies
SOURCE: Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Posted on Feb 25, 2008
SOURCE: how to reset tax % on casio HR-100tm
the 0 disappeared and reappears. Then type in your tax rate and the
percent key (Eg: 8.25%) and then press the TAX+ key. It should save the
new tax rate.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 04, 2010
SOURCE: THE CASIO HR-100TM HAS AN E ON THE SCREEN AND
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service.
http://www.casio.com/support/techsupport/AABF4C3A-D2EF-4BF5-B349-48459AF35FF0
Posted on Mar 01, 2010
SOURCE: Is there an ink cartridge/ribbon to change on the
You need an IR40T Ink Roller
Posted on Mar 26, 2010
SOURCE: how to load paper in
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Posted on Sep 21, 2011
Aug 07, 2018 | Office Equipment & Supplies
May 06, 2017 | Casio Office Equipment & Supplies
Jan 03, 2017 | Casio HR-100TM Printing Calculator - 12...
May 14, 2016 | Casio HR-100TMPlus Calculator
Feb 23, 2015 | Casio HR 100TM Portable Printing...
Oct 10, 2014 | Casio HR-100TM Two-Color Portable Printing...
Jan 18, 2010 | Casio HR-100TEPlus Calculator
Jan 05, 2008 | Casio HR-100TEPlus Calculator
89 people viewed this question
