Is the carb to a snowblower engine?
fuel flow is suspect.
1. loosen gas cap (sometimes the vent in it does not work and tank gets airlocked
2. fuel line on? is there a on/off valve?
3. fuel filter ok?
4. water in line or tank could now be ice...only additive i use is k-100 from napa to keep fuel fresh and blended vs ethanol phased seperation.....also remember fuel is now 10% ethanol (which is basically dry gas)
5. easiest test is to partially loosen carb float bowl bolt at bottom of bowl....don't remove it, just loosen enough to see if fuel comes out.
6. was primer airline hooked up? https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/tecumseh/4-cycle-horizontal/lh195sa/lh195sa-67418v/engine-parts-list
7. whatever it is can be fixed ...keep at it
SOURCE: 2002 chevy Blazer hard starting
This sounds like the fuel pump is shot. The pump has a 'dead' spot and when the engine is started by using 'nasty' starting fluid it will go to the running mode and run fine. Never use starting fluid!!! A bit of gas is best, just use common sence. Frankster016
SOURCE: Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
SOURCE: 4.5hp tecumseh won't start. replaced sparkplug and
I have a Sears Craftsman Vacuum/blower with a 4.5 Tecumseh that wouldn't start. I removed the screw on the bottom of the float bowl and cleaned both the bowl and the screw. The screw has two small holes on each side which feed gas through the middle of the screw up into the carb. There was gunk which had clogged the holes and therefore no gas was getting to the carb. Once cleaned and reattached, the engine ran fine. Unfortunately, I also took the air filter housing off the carb and one of the two screws stripped while putting it back in. Be careful when threading any screws.
SOURCE: Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
SOURCE: how to clean boat carburetor
Carburetors are tricky, They have to be completely dismantled, soaked in carb cleaner, make sure all the gunk is off, every jet clean and clear, If you can't get a wire through it, you won't get gas through it, make sure you can blow through it, Get some guitar strings, .009 is about the smallest guitar string you will find, you can buy them separately at the music store if you don't have one. Change the filter in the line, when the carbs go back on, the adj all have to be the same, not one wide open and 2 idleing, Float level is also important, they don't sell complete kits anymore, you have to buy the parts individually, gaskets , etc, good luck.
