Have you checked the transmission fluid? Check the level and color. The color should be red, not dark or brown.
On an older car, changing the transmission fluid can actually cause more issues, so check the Honda forums (just Duck Duck Go search and you'll find them).
Some cars have a transmission filter that can get clogged as well.
Let us know if this helps.
SOURCE: how to fill automatic transmission on '97 Honda Passport 4X4
There is a metal fitting bolt close to the bottom of the transmission. You can unscrew that out and if transmission fluid comes out it's good. If this doesn't occur you'll have to get a pump and pump transmission fluid in it. This is the easiest with a lift of course. Don't you hate stupid Japanese ideas. Good luck man
SOURCE: HOw do I check the transmission fluid on a 2001 Honda Passport
on level ground with the engine at idle pull out the dipstick wipe it off and check that the fluid is between the two marks. Keep the level near the top mark but do not overfill.
SOURCE: I cant remove a rear axle seal to a 1999 honda passport
Axle bearing and seal are made together. It is pressed on axle.
SOURCE: 1999 honda passport. clunks when stopping and a
have the rear chunk and front chunk checked out could have slack in gears.
SOURCE: Where to check transmission fluid on honda
checking the transmission fluid of the honda passport is not an easy job. the cap is located at top of the transmission, determining the fluid level is by feel.
