Question about Air Tools & Compressors
My air compressor don’t work on my duralast gold 1200 Power station
Posted by Alric Copeland on
Sattech
  • 22 Answers
Looking at duralast specs it only supplies 200 watt ac power...don't know what compressor you are trying but most have HUGE startup power required 1200 watts or more ...S.O.L.
Hugh
Posted on Jan 03, 2018
1 Related Answer
Randy Ohler
  • 14585 Answers
SOURCE: Ignition Control Module Price:$113.99
Replacing all this you surely set the alarm off. Turn the car on, don't start . let sit for ten minutes, turn off, don't remove the key. do this three times. after the third time you turn it off, if it was the security, then the car should start. Let me know And we can go fdrom there.
Randy
Posted on Dec 02, 2010
My Duralast Gold Jump Starter does not take a charge when I plug it in to the wall socket. While the charger is connected to it, it will show the green light. But when I remove the charger, after...
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
Feb 20, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
I have a duralast jump starter BP-DLG. i cannot get it charged. i have pluged it to a standard electrical outlet and now it is dead. i have used it in the past and it worked very well. i mis-laid my...
My Duralast Gold Jump Starter Model BP-DLG will not take a charge. When it is plugged into the charger it shows fully charged; when I unplug it it goes dead, will not start and the red light shows. I have used it about 4 times in less than two years.
I have a Duralast Gold Jump Starter.I charged the battery green light is on but when I try to start a car engine it looks like the jump starter does not have enough power to do the job. Note.- I acquire...
I had the same problem today and I found out that is the battery itself causing the problem. It's actually the connection. So disconnect the battery and scratch the battery pins and connect them again. If you can dip them in soda water (no sugar in it!) that would be better.
This problem starts as the battery beggins to get old and combined with cold weather outside becaomes a receipe for disaster. Anyway, if you can't afford a new battery at the moment remove your battery from your car (but first try and drain it totally...leave a light on or something) and recharge it (fully) with the duralast (havbe the duralst plugget into a outlet). It will have your battery working for couple of weeks.
Dec 03, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Air Tools & Compressors Logo
309 people viewed this question
Top Air Tools & Compressors Experts
Joe Garcia
Joe Garcia
Tom Chichester
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
