Question about Locks & Locksmithing
Locked out of house. Weiser code doesn’t unlock door. Lost key. Any suggestions??
Posted by Jeannine Undershute on
Mike Jones
    Habit-Forming:
    Scholar:
  • 106 Answers
A. Press the program button on the interior unit once.
  1. b. Enter in 4 to 8 digit code onto the keypad.
  2. c. Press the "LOCK" button to save code.
Hope this helps
Posted on Jan 03, 2018
kelly
    Master:
  • 614 Answers
Change battery, push reset button and reprogram
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
Coaltowner
  • 963 Answers
SOURCE: My Weiser Lock won't completely turn the lock
Good news! Weiser has a lifetime warranty against mechanical defects and problems with the finish (but only a one year warranty protecting the internal electronics). Here's the link to the warranty page:
http://www.weiserlock.com/CustomerService/WarrantyInfo/Powerbolt.aspx
But before you pursue that, a few questions and comments. How does the lock function with the door open? If it functions okay, then you need to investigate the alignment between the door lock and the door jamb/strike plate. Also, these locks can be internally adjusted for installation in doors with a 2 3/8" or 2 3/4" backset. Is it off by about 3/8"? if so, check that.
Some months ago I suggested that possibility to someone else with much the same problem. He found that a plastic member had disintegrated in that area of the lock and was jamming it up.
Here's a link to the installation instructions; you'll see what I'm talking about under Item 2 Deadbolt Latch Installation (Piece B)
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
A note about PDF files: If you cannot view the installation instructions, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck--and please leave feedback if this helps!
Posted on Nov 15, 2011
Coaltowner
  • 963 Answers
SOURCE: Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Posted on Aug 19, 2012
danielm85948
Daniel Mc Entee
  • 1449 Answers
SOURCE: I just installed a weiser keyless entry lock. I
check the linkages inside the door .may need adjustment.
Posted on Dec 19, 2013
Why do my weiser smart key locks turn to the 3 o'clock position?
I looked at the Weiser site and although it describes the method of re-keying the locks it doesn't make it clear whether the key can be removed in the 3 o'clock position without the learning tool being inserted.
If the key can be removed in that position it would seem it would only need the key to be reinserted and the lock turned back, though somehow I doubt it as that would rather defeat the object and mean you wouldn't have to keep changing the locks.
Whatever the cause is, it would seem either one of the staff or one of the residents is having a game with you, perhaps they have seen this youtube video...
https://www.youtube.com/watch?v=sR-h64WwfW8
Jun 18, 2017 | Smart Cars & Trucks
Nov 14, 2011 | Weiser Lock GED1460X15A Antique Nickel...
Hi i have a weiser GA331P privacy door knob set in my bathroom door, and i have noticed that it can be pushed in and in the locked postion and when the door shuts it stays locked. I am concerned thay...
the weiser set should have a tiny hole in the knob or rosette around the knob. A paperclip or such can be pushed into the hole to unlock the door. That is the primary difference between a privacy lock and a security lock. Farmerbear at FixYa
Oct 19, 2010 | Garden
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
The kids locked the bathroom door and closed it... my
if not a key hole stick small screwdriver or any small flat devise into handle and turn will unlock passive door handle
Oct 19, 2009 | Weiser Lock Locks & Locksmithing
Center button unlocks insted of locks code locks insted of unlock
Jan 22, 2009 | Weiser Lock Powerbolt 1000 Lock
Locks & Locksmithing Logo
657 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
