Heating & Cooling Logo
Ann Buckham Posted on Jan 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sunbeam two control mattress heated pad. One side works fine but the other will show a F error when put on preheat..
kelly
Level 3:
Master:
  • Master 616 Answers
  • Posted on Jan 03, 2018
kelly
Master
Level 3:
Master:
Answers
616
Questions
Helped
180032
Points
1917
Look for creeses in liquid lines. also check fualty wiring for voltage. switch power to pads if it heats look at power supply
5 Related Answers
A
Anonymous
  • Posted on Nov 25, 2008
SOURCE: the controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
Anonymous
  • Posted on Jan 10, 2009
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Anonymous
  • Posted on Nov 28, 2009
SOURCE: new heated mattress pad won't warm up. Controls keep blinking.
i've lost my control for a king size electric blanket. it had dual control-can u tell me where i can get one and the cost. thx
woodzowl307
  • 679 Answers
  • Posted on May 22, 2010
SOURCE: my sunbeam electric blanket - the heat controller ...
do away with the blanket, as it is an electrical issue, hazard!
Anonymous
  • Posted on Sep 28, 2010
SOURCE: Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Sunbeam heating pad model 828-511 is showing F2 on controller
Hello, Pat -
I can only find that the F2 error code means there is "a problem;" not what the problem is.
I suggest you go to this Sunbeam web page for your model of heating pad:
http://www.sunbeam.com/pain-relief/back-and-spine/sunbeam-microplush-body-shaped-heating-pad-with-digital-lcd-controller/000828-511-002.html
You should see a link for "Live Chat" on the right side of the page. Click or tap on "Live Chat" to text with a Sunbeam Customer Service Representative. He or she should be able to explain the F2 error code and what can be done to correct it.
Best wishes.
I have a 2 control mattress heater. One side works fine but the other will show a f error when put on preheat
Unplug the power cord from the wall outlet. Check that the control is tightly connected to the module in the blanket. Re-plug the power cord into the wall outlet. On a digital control, you should see flashing symbols and the display on your control will clear.
Jan 03, 2018 • Furniture
2answers
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
One control works and not the other control
I have a Sunbeam electric blanket. One control is blinking F2. How do turn that off?
I have a Rest and Relieve Therapeutic King Heated Mattress Pad that I have lost the remote control for. where can I purchase a replacement remote?
You should try to contact the supplier of your mattress cover. If they have a website, you can check their website to check if they provide the separate remote for that particular mattress. Even if they don\'t, you can contact them asking the solution.
Jack
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Greetings, I purchased a full size heated mattress pad with a single off-hi-lo-off control switch several decades ago and the fabric covering the heater elements has deteriorated thus exposing the...
I don;t think there is any repair that is possible and you will need to replace your mattress pad. I would recommend you contact sunbeam directly at sunbeam.com and see if this model has a lifetime guarentee.I tried but they wanted to know how old it was and other info that I could not provide.
If you have had this good of service from their product then I would let them know and maybe they will work with you.
I have had good results contacting companies and praising their products and it don't cost much to try. Thank you
The controller on my heated mattress pad blinks
Top Sunbeam Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
