Question about Water Water Heaters
I have a titan scr2 n120 and the two red lights are not coming on and not providing hot water at all. the unit is a few years old and was working fine. the green light is on. i have tried reseting the unit but no luck. what could be the cause ?
Posted by Brad Beal on
3 Related Answers
Anonymous
SOURCE: Titan-SCR2 N-120, water heater, need schematics
I have taken pictures and produced a wiring diagram for this model
Posted on May 11, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a Titan SCR2
Have you tried the reset button???
http://www.fixya.com/support/t2879586-titan_scr2_stopped_working
There is very little help for these...you can also try the number on the unit for service, but I've heard that they are worthless also...
Other then that check for power at the elemenst and see if you are getting power to them but they are not heating... this would indicate a bad heating element...
heatman101
Posted on Feb 13, 2011
Vic.K.
SOURCE: scr2 titan water heater. No hot water. Both red
On the left side of the board there is a 10K 5Watt resistor that gets loose from the board because of overheat and it needs to core solder back with soldering iron.
Posted on Mar 28, 2012
Where is the reset button on a titan flomaster
were can I get repair service now Titan Scr 2 N120,In Spring Hill,Fl
May 15, 2014 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Scr2 titan water heater. No hot water. Both red
Apr 28, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
When turn on the hot water only the top red and green lights are on and the water is not hot
is it wired correctly..check all your wiring
if its a new install call the place of purchase or the manufacturer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Feb 05, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Hot water is running very slow
Definitely calcium is your problem. If you want to work on this your self turn off the power and drain the tank into a bucket, you will find lots of calcium in the tank. Rinse it out a couple times with fresh water, and vinegar.
May 07, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Jan 23, 2009 | Water Heaters
Water Heaters Logo
4,890 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
