It sounds as though it has power
SOURCE: I have an older Whirpool fridge it isn t cooling
does the motor run if not change the thermostat but if it runs the gas level are low in the system
SOURCE: Model ZHSC02PP-- Mini fridge no longer cooling (18-24 months old)
not much to do, if you've turned it up and it don't help out any, check it on the evap core (big tank in back hole) if any lines are frozen, its low in freon, if not and its not even getting above room temperature then it could either be the switch relay or could be completely out of freon and its not worth fixing, cost more than getting a new one. I found a GE at big lots for under 100 and it has a seperate freezer from the fridge (like a full size shrunk) that works nicely and i've had it for quite some time. Around 3 years i guess.
