Question about Canon Office Equipment & Supplies
Why my canon printer is saying paper jam? - Canon Office Equipment & Supplies
  • jennifervinget
    jennifervinget Aug 21, 2018
    If paper jam in your printer then no stress about it just contact our Toll-Free Canon Printer Support Number:- 1-833-284-3444 https://servicenumber.org/canon.html
Andrew
    New Friend:
  • 18 Answers
Here is nothing wrong in saying, "paper jam issue in canon printer " one of the most irritating issue.
especially when you are going to print any import document and it got stuck in the middle of printing.
when we face paper jam issue with our printer. we always try to contact to a technical expert for fixing such kind issue. while most of us don't know, you can fix paper jam issue in canon printer by yourself without inviting any technical person at your home.
For More details check this
how to fix paper jam issue in canon printer by myself Fixotip
Posted on Jan 02, 2018
5 Related Answers
Ekse
  • 13434 Answers
SOURCE: Canon MP140 paper jam error with no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Anonymous
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: Printer keeps saying there is a paper
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Posted on Apr 25, 2010
Mike
  • 4369 Answers
SOURCE: I have a canon printer and it says paper output
WEll, take it apart and look for tiny paper shreads stuck somewhere...then unplug power for at least 60 sec. and try again.
Posted on Sep 06, 2010
Canon iP 1600 printer won't print. Says that
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
When loading printer it says there is a proiplem
your printer getting the paper jam error.......
first try to check wether the paper jamed or not...
then if still displaying paper jam then try to rest the printer or open the printer then clean the all parts then plug it.
for maor details go to the canon website...
ok then bye ................
Nov 05, 2009 | Canon iPF700 InkJet Printer
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Paper jam
Same problem here. Paper Jam, but there is no paper jammed in it the printer?  Know it should say tire jam because I put it in my driveway and drove my truck over it. Problem solved. Stay away from canon printers.
Sep 16, 2007 | Canon PIXMA MP460 All-In-One InkJet...
74 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
