Question about Internet Computers & Internet
How to fix script error in Internet explorer?
Carlos L. Glez
    Loyalty:
    Visited the website for 30 consecutive days.
  • Internet Master
  • 419 Answers
Hello, fortunately soon Internet Explore is intended to discontinue the merger of Microsoft Edge - Chromium, (waiting for that moment) The first thing you should do is (as a preventive measure) to clean the Temporary Files, Cookies, and History
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. Click the General tab.
  4. Under Browsing History, click Delete, and then click Yes when you are prompted to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and then click Yes when you are prompted to confirm.
  6. Under Cookies, click Delete Cookies, and then click Yes when you are prompted to confirm.
  7. Under History, click Delete History, and then click Yes when you are prompted to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
I attached an instructional video with more details to solve this problem.
Posted on Apr 20, 2019
5 Related Answers
Mike Waldron
  • 1019 Answers
SOURCE: fix script page error
re-install the program internet explorer.
or go to ( On your computer ) Start/all programs/accesories/system tools/system information.
From there you should have an option to repair internet explorer.
Mike @ Compurepair.
Posted on Feb 22, 2008
Anonymous
SOURCE: Internet Explorer Script Error
please stop error http://db2.t.msn.com/en-gb/home.aspx?ver=8.5.1302&did=
Posted on Nov 18, 2008
Shamsh
  • 81 Answers
SOURCE: Ymsgr Chat Rooms
Go to start-->>control panel-->>internet option go to advance tab uncheck these entries. disable script debugging(internet explorer) disable script debugging(other)
restart the computer
Posted on May 10, 2009
NextStepComp
Brad Hays
  • 185 Answers
SOURCE: Internet Explorer Script Issue ?
If you want to disable Internet Explorer's displaying windows when there is a script error on a page,
  2. Go to Tools / Internet Options
  3. Click on the Advanced tab
  4. Under the Browsing section, check Disable script debugging and uncheck Display notification about every script error
    Source: http://www.onecomputerguy.com/ie_tips.htm#script_debug
Posted on Dec 31, 2009
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
SOURCE: internet explorer script errors in facebook
    Select 'Tools' from the toolbar menu.
    Choose 'Internet Options.'
    Click on the 'Advanced' tab.
    Scroll through the list of options until you see the heading labeled 'Browsing.'
    Put checks in the boxes labeled 'Disable Script Debugging (Internet Explorer' and 'Disable Script Debugging (Other).' When you have done this, click 'OK.' You should no longer see script error messages when you cruise the Internet.
Posted on May 01, 2010
How to fix a dell Inspiron notebook that says long script running?
  • Open Internet Explorer
  • Click the 'Tools' menu, and then select 'Internet Options'
  • Click the 'Advanced' tab, select the 'Disable script debugging (Internet Explorer)' and 'Disable script debugging (Other)' check boxes
  • Clear the 'Display a notification about every script error' check box, and then click OK
Jun 12, 2014 | Dell Computers & Internet
Long running script zedo.com
I understand that you are getting the script error. Refer the link for the information to troubleshoot script errors in Internet Explorer:
http://support.microsoft.com/kb/308260
The information contained in the link Applies to
  • Windows Internet Explorer 9
  • Windows Internet Explorer 8
  • Windows Internet Explorer 7
  • Microsoft Internet Explorer 6.0
You may also try reset the Browser and check the operation.
Nov 18, 2013 | Dell Dimension Computers & Internet
Script problem in Explorer 8
What should you do about Internet Explorer script errors?
In most cases, you can ignore them. Script error messages are displayed by Internet Explorer when there is a problem with the JavaScript or VBScript code on the website you are viewing. Occasionally a script error can be caused by an error in downloading a webpage, but more often it is an error in the webpage itself.
To be sure it isn't an error in downloading, click the Refresh button, or press F5.
getcontent.aspx?assetid=6d65df30-1154-45a1-9855-1232c6b27475&documentset=en-us&prod=win700&market=usInternet Explorer refresh button
If the error persists, and you are not a developer testing a website, you should click No to ignore the error.
To avoid script errors in the future, you can turn off script debugging and notifications in Internet Explorer. Script error debugging and notifications are turned off by default. If they have been turned on, follow these steps to turn them off again.
  1. Click the Tools button, and then click Internet Options.
2. Click the Advanced tab, select the Disable script debugging (Internet Explorer) and Disable script debugging (Other) check boxes.
3. Clear the Display a notification about every script error check box, and then click OK.
Apr 25, 2011 | Microsoft Internet Explorer 8
Running script error
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  3. In the Internet Options dialog box, click the Security tab.
  4. Click Default Level.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  4. Under Temporary Internet files, click Settings.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
Jul 06, 2010 | Computers & Internet
Internet explorer script errors in facebook
Apr 30, 2010 | Facebook Social Network
Internet Explorer Script Issue ? When I mov from Homepage to profile n IE Script error dialogue box opens
Dec 19, 2009 | Computers & Internet
Internet Explorer Script error
You may have scripting disabled in your Internet Explorer.
To enable scripting:
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
Dec 07, 2009 | Yahoo Messenger
Fix script page error
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
 Grubhead
Grubhead
Geoff
Sharps s
