Cameras Logo
Anonymous Posted on Jan 02, 2018
Just got iclever Boostcell ECE series external battery charger, where is the plug for me to charge the battery charger before I use it?
Tony Parsons
Level 3:
  • Cameras Master 6,405 Answers
  • Posted on Jan 02, 2018
Tony Parsons
Cameras Master
Level 3:
Answers
6405
Questions
Helped
1650168
Points
20272
Have you looked in the manual for advice ?
5 Related Answers
Anonymous
  • Posted on Mar 25, 2008
SOURCE: External charger for battery?
I had the same problem just today,when I turned my Zen on after like 6 months- zen working fine from the charger but battery would not show any charging[no battery icon].What I did is cut the output cord from charger and strip the two wires just a little bit and hold the bare ends straight on the battery contacts - and + [plus is the one with white stripes] for like 30 seconds and than put the battery back to the Zen,turn on the zen [without the charger pluged in] and it worked,showing slightly charged battery,so I pluged the charger back and it started charging the battery normal like before.Hope this helps,Lukas
Anonymous
  • 1884 Answers
  • Posted on Jul 28, 2009
SOURCE: Nokia 1100 not charging from external charger
Ther charging circuit seems to be defective or your charger is gone. Try and test the charger elsewhere.
Anonymous
  • 42 Answers
  • Posted on Mar 25, 2010
SOURCE: my psp 1000 does not charge
mine won't charge either so i don't know...?
Anonymous
  • 481 Answers
  • Posted on Jul 14, 2010
SOURCE: I own a ibook G4 1.42 ghz and the battery no
I'd try another AC adapter first. It's not unknown for them to go bad and no longer deliver the power necessary to charge the battery. It's really unlikely for the charge circuitry internal to the iBook to go bad.
dheeraj jain
  • 33 Answers
  • Posted on Jun 06, 2011
SOURCE: the battery on my 5230
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
I have an Invacare Pronto M-91 Sure Step Electric Wheelchair that when plugged into wall socket is no longer charging chair batteries. The onboard Signet charger's led light isn't illuminating at all when...
The charger is defective. I would not try to charge it externally because if you charge it with a higher rate of current (amperage) than the original charger, it could explode or leak.
Will not charge when plugged in
have you tried an external battery charger and a different battery?..... maybe its the camera not sending power to the battery..... or the battery is good and the camera is dead, the external charger will help you decide where the fault is.
2answers
Wireless headphones
Maybe your headphone has broken. You can buy new one from Mubuy
1helpful
I have a pavilion dv 7 that shutdow the otherday.The battery was hot and if i turned the pc back on it would run for a couple minutes then shutdown.The charger was also hot. I purchased a new battery and...
There are isues with HP external power supplies - if it is a dv7-3xxx series you require AC Smart adapter (120 watt) - 100-240VAC input, 50-60Hz, 2.5A - 18.5VDC output, 6.5A, Pt No 463953-001
for earlier models require AC Smart power adapter (90 watt) - 100-240VAC input, 47-63Hz - 19.0VDC output, 4.74A, 90 watts, with power factor correction (PFC) 463955-001
If you are within the warranty period utilize that warranty if not contact HP and see what price a replacement external power pack is.
1helpful
Can i use my plug for the computer to charge my camera? if so how? its not working!
Sorry, but the USB cable is only for downloading photos to the computer, and the 300 series cameras do not have an on-board charging function. If you wish to use rechargeable batteries (Polaroid recommends Ni-MH type only) you must purchase and use an external charger. Inexpensive generic chargers can be purchased in the electronics department of most stores.
1helpful
2answers
My Insignia HD DV HDMI will not charge!!!
Occasionally the batteries in the camera die- so no amount of charging will fix that, but does the camera work when you have it plugged in to charge? Most cameras will run from the  charger , even if the battery is dead. If it runs from AC (wall plug), but not battery, it probably the battery, but occasionally it is the circuit in the camera that charges the battery. The last resort is an external battery charger (not all cameras have them), but if you can charge the battery elsewhere, then it is the circuit in the camera- you'll have to buy an external charger if one exists
3helpful
2answers
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
