Question about HP Computers & Internet
I need help please anyone i have no sound coming from my hp stream 11-d009tu i have uninstalled and re installed my auido drivers and still nothing
Its telling me one or more probrams not working or endpoint i have team viewer 13 if that helps
Posted by Terrance Johnston on
Larry Ng
  • HP Master
  • 6,054 Answers
Step by step inch by inch
BT sound ok
HDMI sound ok
main sounds dead. at internal and at ext. 3.5mm line out jack dead.
that means BIOS has that chip off , so go to BIOS and turn it on
if it is on, the get the driver from HP
you have yet told the full service tag data here.
so i cant even go to hp for you and ask them can I.
so why dont you go to hp and ask them
and they will ask you for the service tag, or fails.
Posted on Jan 02, 2018
Testimonial: "No nothing if i connect bluetooth or hdmi i have sound no sound from 3.5 jack or pc speakers"
  • 2 more comments
  • Anonymous Jan 02, 2018
    learn that This PC has 3 sounds devices
    the intel GPU set does HDMI sound.
    the Bluetooth has its sound decoder
    and last the main sound chip(runs the 3.5mm jack and the internal speaker.
    guess which one is borked up?
    the reason it's dead is here.
    1: the main chip was turned off in BIOS by kids or some one.(LOOK YET?)
    2: the driver was replace with the wrong one. killing it dead. (KIDS AGAIN)
    3: or other reasons, why not ask HP real for the correct driver, and not ask here at fixya. we have no drivers here. ok?
    go to HP.com
    ask on theRE forum
    HP experts then beg for the service tag
    data.
    you fail that and you fail.
    the tag shows a nnnnnABA# number
    these codeS tell them what chips were there day 1 new.
    if Your reloaded the F11 HP recovery and are on line now, and the sound is dead.
    Id first guess that its turned off in BIOS.
    your PC can in fact have vast numbers of different mother boards, (sound ,and more.
    why even ask lacking that fact.
    for sure at HP.
    you could also.
    go in to bios and flip the reset bios to defaults and then the chip wakes up.
    It must show up in device manager and yours is missing. i see.
  • Anonymous May 22, 2018
    "No nothing.(dot period) except...
    if i connect bluetooth or hdmi,then i have sound .but
    the periods really helped.
    But yes if figured it all out.
  • Larry Ng
    Larry Ng May 22, 2018
    I do not do house calls ever.
    im retired now, that ended 10 years ago.
    in some cases,(facts are great no?)
    HP even needs 3 numbers to match a driver.
    serial numbers in some cases.
    and again, Im not HP nor do I have access to any data bases with HP serials in it.
    I know of no non HP tech that has that secret
    why not ask HP, is your ISP blocking HP.com
  • Larry Ng
    the sure i always look in BIOS first
    to make double sure the kids did not play there, and turn off the sound chip.
    kids = whomever did it for whatever reasons ever.
    on OLD PC , we make sure the RTC coin cell is good. 5-7 year life span
    if not good cell, the bios goes nuts
    even losing sound.
    time of day or date.
    and endless pain there... first things first
    RTC coin
    BIOS reset.
    make sure the sound is enabled in BIOS.
    the in windows load the HP driver from HP.
    end story.
    again it must match your service TAG data.
    unstated by you nor did you ask HP and answer the same question from them.
5 Related Answers
Anonymous
SOURCE: realtek
jjjjjjjj
Posted on Apr 03, 2008
Anonymous
  • 18 Answers
SOURCE: ADS Tech Instant TV+FM PCI (PTV-351) Not working on Vista
From what? more details please.
Posted on Dec 31, 2008
Anonymous
SOURCE: HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Posted on Feb 16, 2009
Anonymous
  • 68 Answers
SOURCE: can't update symantac 11
please see to it that the product is genuine
When live update fails, it is most likely due one of the following reasons:
· No license file (*.slf) is installed
· The installed license file (*.slf) has expired
· The trial period has expired
· The installed license file (*.slf) has been deleted, or become damaged or corrupted
· The software is not able to able to communicate with the Symantec servers
It is necessary to have a valid license file installed into the program to authorize it for the download of the content updates using Live Update.
It is necessary to register your license(s) at the Licensing Portal (https://licensing.symantec.com/) to generate the license file if it was not included with your license certificate (*.pdf).
The license file (*.slf) has expired
It is required to have a current support contract to be authorized to have the most current content updates downloaded. If you have renewed your support contract, it is necessary to register your license(s) at the Licensing Portal (https://licensing.symantec.com/) to generate the new license file if it was not included with your license certificate (*.pdf).
This could also be the case if you have a current support contract, but had a trial license key installed in the software. It is necessary to register the support contract renewal to generate the new license file.
Many of Symantec's products offer a limited-time trial period where you can test the software in your environment. When the trial period expires, the software will typically cease to function as part of the Trialware installation agreement.
The installed license file (*.slf) has been deleted, is damaged or corrupted
If the license file that was installed in the program has been deleted or is corrupted, it is necessary to reinstall the license.
You can re-download the license file from the Licensing Portal account the license was registered in. If you registered the license into your Licensing Portal account, you can log into your account and re-download the license file. If the license was registered into the account of another person, you would need to contact that person to have them re-download a copy of the license file or provide you access to re-download the license file from their account.
The software is unable to communicate with the Symantec servers
The Symantec software must be able to establish a connection to the servers to be able to download the current content updates. If the software is unable to establish the server connection, then it will not be able to download the content updates.
You would need to check your network security settings to ensure the network traffic is not being blocked. If you believe your network's security settings might be blocking the Symantec software from communicating to the Live Update servers, contact Symantec Technical Support for assistance. You can find the phone number for your region here: http://www.symantec.com/business/support/contact_techsupp_static.jsp
One example of this occurring is when trying to install a license file into Symantec Mail Security 4.6 or later you get the following error message: "Symantec Premium AntiSpam registration failed. The product will not receive definition updates".
Here is a link to a technical support document with more information on this issue and possible resolutions: http://service1.symantec.com/support/ent-gate.nsf/854fa02b4f5013678825731a007d06af/e0395129f0bedbf4882570d2006ad1af?OpenDocument
(i took it from "http://customercare.symantec.com/app/answers/detail/a_id/81/kw/update/r_id/166" )
Posted on Apr 22, 2009
Anonymous
  • 87 Answers
SOURCE: When I try to print on my HP 2420 I get a box that says print
Uninstall the current drivers, install UPD PCL 5, and upgrade the firmware of the printer.
Driver for OS:
Operating System(s): Microsoft Windows Server 2003, Microsoft Windows Server 2008 W32, Microsoft Windows Vista, Microsoft Windows XP
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&prodNameId=412142&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-35999-16
Firmware sw link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&prodNameId=412142&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25074-6
Posted on Sep 09, 2009
How to disassemble hp 11-d008TU/d009TU W8.1 Netbook'
Hi George,
I see that you are looking for instructions on disassembling your Stream Notebook. What seems to be the problem with the Stream? Perhaps, I can help.
If you have purchased this within the last year then you are in warranty and I wouldn't recommend taking anything apart as that may void the warranty. I can try helping here or you can contact HP at www.hp.com/contacthp
If your still looking at taking it apart I have included a link below to the Maintenance and Service Guide for your model. The instructions start on page 28 of the guide.
Maintenance and Service Guide:
http://h10032.www1.hp.com/ctg/Manual/c04491261
Thank you,
BHK6
I work on behalf of HP.
Hi, could someone please help me with sound problems.. Today it broke down - don't know why, because nothing has been updated/installed or uninstalled.. I have searched in WEB for possible...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
3helpful
I installed the sound driver and can hear almost no sound
Did you un-install the original drivers before you installed the new ones?If you had installed the drivers before you un-install them,remove them and reboot.When windows comes up reinstall the drivers.
Good Luck
Cannot install hp4280 with vista
hi thanks for using fixya!!
First, try to update your windows.
Please check the CD that came with the printer, see if the driver is version 8.0.0 from May, 2007. If its not, uninstall your current driver.
Please click here to download your driver
When installing the new drivers, make sure that your printer is turned off and not connected to your PC. Just run the installer file, and only connect and power on the Printer when the installation says to do so.
If you need further assistance, please let me know.
pls rate my solution positively! thanks
2answers
Sund card porblem
Hello my name is Tim Ehrhart, it sounds to me like you need to download new sound drivers for your pc, here is a link for you www.devicedriverdownloads.com I hope this helps, speaking of helping could ou please leave me feedback as I am new and am trying to build rep. Good luck and please contact me if you need any help.
2answers
Sound driver
By default, your Notebook will be shipped either with Conexant or Realtek High Definition(HD) Audio for which you need to install the Microsoft Universal Audio Architecture (UAA)drivers before installing the Audio Drivers if you are using Windows XP.
The required Microsoft UAA Drivers which need to be installed before installing the audio drivers are available through the link below :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
Save the file in the Notebook and double click it to install after the file is saved.
Restart the Notebook after the completion of installation of Microsoft UAA Drivers in the Notebook.
Now, download the Conexant High Definition audio drivers for your Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Save the file in the Notebook and double click it to install once the downlooad is completed.
This should solve the issue with installing auido drivers in your Notebook.
Alvan and The Chipmunks reside in my Gmax 2100 speakers!
If you have a sound card added on your motherboard, i suggest you uninstall the drivers, take off the sound card, attach it again and install the drivers.
If you connect your speakers through the motherboard itself, uninstall drivers and install them by searching C:\WINDOWS\system32\drivers
Hope it helps!!!
3answers
Lost all sound
I have this same problem with my computer.  The only way I have been able to get sound back is to uninstall the drivers.  It sucks because I have to re install them everytime I use my logitech camera.  I have a HP laptop.   I hope someone has a better solution.
19helpful
10answers
Conexant CX 20549 Audio and Conexant CX20548-11 Modem drivers
for WIN XP32 SP2 try
1.instal sp36880.exe (Intel Chipset Installation Utility for ICH8 2K_XP)
2.instal sp33867.exe (Microsoft UAA Bus Driver for HD Audio)
3.try instal sp36090.exe (Conexant High Definition Audio) but 99% with errors !!! (extract to C:\sp36090 )
4.in DEVICE MANAGER / SYSTEM DEVICES
right click on PCI DEVICE (there is yellow trouble icon), manual search "C:\sp36090" and final instal DEVICE )
5. then instal next devices :))
sp36089.exe (HDAUDIO Soft Data Fax Modem with SmartCP)
and so on
jovany
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
