Question about Canon Office Equipment & Supplies
I have an older Canon ipf5000 that i hardly used. I'm trying to start it up again and it gives me this error: Carriage Motion Error. what does that mean and how do I fix it.
Posted by Jo Ann on
NAJI AZAR
    Habit-Forming:
    Scholar:
  • Canon Expert
  • 94 Answers
Look for a thin mylar strip running behind the printheads which should be sitting in a little guide tab, but has probably fallen out. Put the mylar strip back in place. Recommended by Canon support, one poster reports permanent resolution of the problem. The Canon tech said he gets about three calls a week for this problem.
Posted on Jan 05, 2018
  • Max Ferguson
    Max Ferguson Jun 15, 2019
    Does anyone have an image of this
5 Related Answers
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
Anonymous
SOURCE: canon mx310 printer
Open up the hood, slide the ink cartridges to the far left, and check for a small silver piece that has dislodged from the far right side of the interior. You will probably need a flashlight to see. It is about the size of a folded paperclip. Even if it is still in place, remove it anyways because the printer identifies it as an obstruction. It serves no purpose so do not feel apprehensive about doing this, it will fix this problem.
Posted on Oct 14, 2008
Robert Kitaji
  • 1335 Answers
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Posted on Dec 19, 2009
Anonymous
SOURCE: Canon Pixma MP145 Error Code for E22 Carriage Error.
how cab i fix e22 carriage problem
Posted on Apr 21, 2010
Magoroku Kai
  • 24 Answers
SOURCE: My canon mp190 gives E3 paperjam error but there i...
I have solved this problem with read post at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html thanks to slayo.com "Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things." you must open your printer to remove the things, maybe waste letter or other small part things. Read the post for complete it.
Posted on Jun 01, 2010
Cannon error e161 403f
this is a 'printhead L' abnormal temperature error
Clean and clear pinhead.
www.usa.canon.com > Home > Support & Drivers
May 27, 2014 | Canon imagePROGRAF iPF5000 InkJet Printer
Canon BJC 5500. It had a paper jam and I pulled it clear which led to a F1 error appearing.
This is a carriage error, try unplugging the printer for a couple minutes and try again. If that fails, you damaged the carriage when you pulled out the paper and the printer will require service.
Aug 05, 2008 | Canon Office Equipment & Supplies
Canon ipf750/upgrade firmware
I would first check the linear scale.That`s a small plastic strip ,positioned along the total lenght of the rail.Mind you ,I don`t have a ipf8000.But maybe the systems are the same.The linear scale is under tension ,by a metal spring.Check if the strip is not hanging loose.Also check the strip (linear scale) on dirt or ink splashes.If so clean it with alcohol (that`s what I did on a ipf5000).The scale runs through a slit ,at the back of the carriage.There are light grey patterns on the scale.The sensor on the carriage reads them ,and thus knows the position of the printheads ,with respect to the rest position.Check if the scale runs smoothly through the slit.
Feb 27, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Close carriage cover ipf8300
I have tried to find this elusive black flap you are refering to ... are you sure we are talking about the Canon 1pf8300 44" printer?
Aug 13, 2012 | Canon imagePROGRAF iPF8000 Printer
I have Error 5100 in my All in one printer Canon MP180
Error 5100 is a carriage error. There is a plastic strip that goes through the carriage, if that strip is dirty, damaged, or has come loose, that will cause the problem.
Power off, check the strip, use a barely damp qtip to very gently clean it, and try power on again.
If you still have the error, it is probably mechanical, and could be any number of things, none of which are easy (or clean) to fix.
Aug 31, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Canon cartidge not recognised
make sure the catridge is not refilled.and you using genuine catridge also you an try all this possiblities to fix the problem
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, .
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA iP1300 Printer
Error 5100
Hi
Thanks for using FixYa. Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip(encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Jun 29, 2009 | Canon MX300 Office All-In-One Printer
275 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
