Question about Kenwood Car Audio & Video
My Kenwood DDX9902S monitor/DVD receiver usually loads or resets on it's own, however a few weeks ago it has "frozen" at the initial logo screen. How can I reset it?
Posted by Miguel Tulier on
Robert Rankin
  • 378 Answers
You van find a manual for your specific device here:
http://www.kenwood.com/usa/car/excelon/ddx9902s/support.html?model=DDX9902S
Posted on Jan 01, 2018
5 Related Answers
Anonymous
SOURCE: Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Posted on Jun 23, 2008
theRainmaker
SOURCE: Creative Zen frozen and Reset has not worked
try this if your Zen will not turn on
hold the pause/play button down
while holding the pause/play, first use a paperclip to press the reset button and then slide the power thing down for a few seconds like you are turning it on.
release the pause/play button.
you may need to connect it to usb for it to turn on. worked like a charm for me when everything else failed. hope it helps!!!
Posted on Aug 08, 2008
SOURCE: Samsung ML2551N: Initialization problem on startup
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Posted on Jan 06, 2009
Anonymous
  • 3 Answers
SOURCE: FROZEN GREEN SCREEN ON XDA ORBIT 2
The only way to solve your problem is that you will have to format your phone by pressing the reset batton along with both function keys in front untill somthing appears on the screen.
Posted on Jan 16, 2009
Anonymous
SOURCE: reset 255 loader loading frozen
Press the reset button - you'll find it on the lower right of the Nüvi 255, but it doesn't look like a button. It's basically the sticker with all the information on it. It's just enough to push the sticker carefully with something small, not too sharp so it doesn' get destroyed. The Nüvi reboots, the loader loads and proceeds with the software load. Once this is over, shut down the Nüvi and reconnect to the PC. Then, everything works fine (it did at least for me).
Posted on Feb 27, 2009
Cannot get it to power on How does it work?
Kenwood Excelon DDX9902S DVD receiver at Crutchfield ...
www.crutchfield.com > ... > In-dash Video Receivers Crutchfield Corporation
Rating: 4 - ‎21 reviews - ‎$674.99 - ‎In stock
Kenwood Excelon DDX9902S Android Auto integrates your phone's app with the ....deliver an ultra-clean signal for adding additional amps for even more power. ...... Only thing I can't get to work with the Apple Car Play is the ITunes radio.
Car Stereos FAQ - Crutchfield
www.crutchfield.com > ... > Car Stereos
Crutchfield CorporationJump to What's the best way to connect the Crutchfield wiring ... - A: Most CDreceivers will play at least ... for example, some receivers work with ... If you can'tfind a new cassette deck ... the remote wire did not power the amp .... KenwoodExcelon KDC-X399 ... 12 tips for getting the best sound quality in your car.
Kenwood KDC-BT362U CD receiver at Crutchfield.com
www.crutchfield.com > ... > All Car Stereos
Rating: 4.5 - ‎174 reviews
A smartphone haven With Kenwood's KDC-BT362U CD receiver, you can ... A newcar stereo offers power that's superior to most factory radios, along with .... Gettingthe installation kit and the wiring harness with my stereo purchase was great. .... Cons: Pandora did not work and I tried contacting customer service and their ...
Kenwood - Car-Audio FAQ
Jan 06, 2016 | Kenwood Car Audio & Video
My iTouch is frozen on the apple logo, with a little loading circle frozen on top of that. there is a little broken line of different colors, very thin, about a centimeter from the top of the screen. I've...
Iv only seen that line with a jailbreak found at jailbreak me dot com... I'm not saying you jailbroke your phone but if it is that you might just be able to restore your iPod from your computer. Try it either way.
Dec 16, 2010 | Apple iPod touch
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
Ipod connecting to Kenwood Car Receiver
I had the exact same problem. There is a RESET button on the face of the radio. I have pressed it with the radio ON, OFF and While Holding the SOURCE (power) Button. My iPods are now working fine with the radio.
-LBJ
Jan 08, 2010 | Kenwood Car Audio & Video
Try to eject cd and it displays 'demostration
hit the little reset button next to the kenwood logo on the bottom of the screen. Or go here...http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/DDX8017.pdf
Oct 29, 2009 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Car dvd player cannot play disk
See if unit has a reset to factory defaults. Also check with Kenwood. If not results are achieved unit needs replacement
Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Sep 21, 2017 | Kenwood Car Audio & Video
Frozen Apple Logo
if itunes recognizes the phone use the restore option if not you need to perform a force recovery mode. to do this hold power and home screen buttons until the screen resets when it does keep holding the home screen button and plug in the phone to the computer after a few seconds itunes should see a phone in recovery mode and force you to do a restore. if that does not work you might have a hardware problem and will need to go to a store.
Jan 24, 2009 | Apple iPhone Smartphone
Car Audio & Video Logo
551 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
