Dryers Logo
Question about Dyson Dryers
Just got the dyson blade less fan but it won't oscillate. What could be wrong
Posted by Billie gaia on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Oscillation works but motor doesn't
try tofix the axle with some glue or so
Posted on Jan 15, 2008
Anonymous
SOURCE: I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Posted on Aug 27, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Soleus FS1-40R-41 Stand Fan When the
Try lubing the fan with a penetrating oil like WD-40 or PB Blaster first before using regular oil.
Also setting the fan on it's front and back for a while to allow the penetrating oil to get into the bearing will help..once the motor is working freely then use a light motor oil to permanently lube the motor, also setting it on it's front and back for a few hours at a time to allow the oil to run into the bearing.
heatman101
Posted on May 17, 2011
gludwick2
  • 60 Answers
SOURCE: blade won't turn. comfort zone 16in.3speedwhite oscillating pedestal fan
I believe your motor is shot. Time for a new fan, I'm sorry to say.
Posted on Dec 11, 2014
loucon8
Louise Conley
  • 3 Answers
SOURCE: How do I fix broken blades on oscillating fan
Broken how? The blades are broken in half or by the screws (located near the motor)?
Posted on Jul 10, 2015
1helpful
New Dyson AM09 hot/cool fan does not oscillate
S Adams, return for refund or replacement, sound like plastic gear inside could be damaged or loose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.dyson.co.uk/support/am09/am09-white-nickel/my-machine-is-not-working/my-machine-is-not-oscillating
https://www.dyson.com/support/am0112/am01-desk-fan-12-silver-iron/diagnosis-root-menu/my-machine-is-not-oscillating-am01
Dyson AM 02 Fan not working oscillating feature is broken
http://www.dysoncanada.ca/en-CA/support.aspx
tip
Dyson Hot + Cool AM09 fan heater - Getting started
How to assemble and use your new Dyson AM09 Hot + Cool fan heater. Adjust the power and oscillation, choose between diffused or focused modes, set the target temperature and sleep timer, and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Nov 27, 2014 • Dyson Dryers
tip
Dyson Cool AM08 Air Multiplier pedestal fan - Getting started
How to assemble and use your new Dyson Cool AM08 Air Multiplier pedestal fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 • Dyson Dryers
2answers
Why won't my fan oscillate?
There is a little arm attached to the motor that makes the fas oscillate. If it gets disconnected you will have that issue. Check the linkage.
2answers
Why wont my dyson fan oscillate?
Hi there, it's Jack at Dyson.
Your Dyson Air Multiplier AM01 desk fan should oscillate when you press the oscillation button on the base:
If you find that it's not oscillating when this is pressed, we'd need you to contact our Support team directly - we can confirm if we're able to resolve this for you under our free 2-year parts and labour guarantee.
You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
tip
Dyson Cool AM07 Air Multiplier tower fan - Getting started
How to assemble and use your new Dyson Cool AM07 Air Multiplier tower fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
tip
Dyson Cool AM06 Air Multiplier desk fan - Getting started
How to assemble and use your new Dyson Cool AM06 Air Multiplier desk fan: adjust the power and oscillation, change the angle of the loop, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
2answers
My minkaAire/Delano11 will not turn on. The green light is now blue. What does this mean
OKAY I HAVE A POSSIBLE SOLUTION! THERE SHOULD BE A GREEN LIGHT AT THE TOP OF THE REMOTE AND A BLUE LIGHT AT THE BOTTOM. YOU NEED TO TURN OFF THE BOTTOM SWITCH, WHERE THE BLUE LIGHT IS, FOR 5 SECONDS THEN BACK ON. THEN HOLD THE CENTER STOP BUTTON FOR 5 SECONDS AS WELL. THIS WILL ALLOW FAN AND REMOTE TO RESYNCHRONIZE, IF BLUE AND GREEN LIGHTS BLINK TWICE THEN U HAVE SUCCESSFULLY RESET BOTH FAN AND REMOTE. IF THIS DOESN'T WORK CALL MINKA AIRE TECH SUPPORT 1-800-221-7977. GOOD LUCK!
2answers
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
