Question about Speed Computers & Internet
My computer download speed is slow even i have high speed fiber connection 200mbps
Posted by gihan senarathne on
amisset
    Champion:
  • 224 Answers
Goodday, this is difficult to analyze without further information: Did you change anything on your computer? How old is it?
Are you using Wifi or a cable? Be aware that download speeds also depend on the server on the other side, so even if you have the fastest fiber internet, downloads from a slow server may take more time.
Did you check your speed with a special program or website? Search for a speedtest online and try how fast your connection is.
200 mbps means that a 700 MB movie / CD image would take about 28 seconds to download.
Check the bits and Bytes converting about how fast your connections should be.
Good luck,
A.Misset
Posted on Jan 01, 2018
Testimonial: "i didn't change anything on my pc. Pc is about 4 years old, branded HP, Pentium Dual-core cpu E5300 @ 2.60GHz 2.60GHz, 4 GB Ram .everything is up-to date. runs windows 10 pro,and i use Norton Security 2017, Ccleaner. I have a cable connection to the router and i checked the speed with speedtest.net and it shows 200Mbps as my download speed and 20Mbps as upload."
  • 2 more comments
  • amisset Jan 01, 2018
    Goodday, then where did you experience the slow download speed? Downloading what?
    A.Misset
  • gihan senarathne Jan 03, 2018
    The problem is my computer is not using that full speed or at-least half of it. when i download a film or watching a full HD video on youtube can see that issue( Take too long to download), when i check under task manager-> performance-> Ethernet, shows only 20mbps or 30mbps(maximum)
  • gihan senarathne Jan 07, 2018
    amisset,,,, please give me a reply,,,,,,,,,,,
  • amisset Jan 07, 2018
    That is then probably the max speed from the server at the other end.
salim rajbally
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Hi, This might be because of virus in your system, or the browser you are using is not up to date, last your antivirus is online just blocking all spams and malwares.
Posted on Jan 07, 2018
5 Related Answers
Anonymous
SOURCE: To solve slow speed surfing,downloading and uploading problem.
i cant download skins in my phone
Posted on Sep 22, 2008
Anonymous
  • 89 Answers
SOURCE: Upload Speeds Slow, Ping High
You may visit this website http://increaseinternetspeed.net/
This website contains the tips about the increase upload speed And You can check Your internet speed in the site http://www.ip-details.com/
Posted on Oct 08, 2009
A Miller
  • 8404 Answers
SOURCE: I have two Belkin powerline adaptors 200mbps type
Your hard disk is failing and should be replaced. Have you tried to press F1 when you get the message? If this doesn't help try to enter the bios and disable S.M.A.R.T.
Your first goal is to save the data so please do that before it's too late.
Posted on Mar 09, 2010
Anonymous
  • 19 Answers
SOURCE: slow download speed on motorola SB4200
open the internet explorer2_bing.gif on the addresss bar put 192.168.100.1 then go to hack add on file adress file d11_m_speedtierextreme2_c01.cm
then on ip server file put 68.87.68.35 the press change id then unplug the modem then plug it back the speed should be back
Posted on May 06, 2010
Anonymous
  • 59 Answers
SOURCE: Very slow connection speed, drops connection &...
which ever router or device u r using for the wireless connection , plz upgrade the drivers for that or u can even visit the website for that product an u will find the details there as well ....
Posted on May 31, 2010
RT-AC66U slow download speeds
Run a test of your internet using www.speedtest.net. You should be seeing ping less than 100 ms, and your download and upload speeds will vary depending on your service. Do you have cable, isdn, dsl, or fiber? cable and fiber should give you speeds of at least 10Mb down 10 Mb up, ISDN and DSL should give you speeds around 500kbps down and 250kbps up.
Oct 17, 2013 | ASUS Computers & Internet
My new Acer Aspire one 722 wireless connection tested fine at the store. Web pages and file download is as expected for high speed network. When I brought it home to my high speed network, web pages and...
could be just different wifi chipsets. these days also you may have 2.4/5ghz(802.11ac) what router do you have? most routers are now DUAL SIGNAL and have a 2nd wifi signal called GUEST generally this is for older slower WEP based security for old devices(which is what you have) as aspire one 722 is 802.11 b/g/N but not 5ghz and not ac. so its slow cos the router probably keeps negotiating for faster connection but your aspire cant do it and doesnt even know about it. Enable GUEST in your router and set it to N. How to Find the Best Wi Fi Channel for Your Router on Any Operating System https://www.forbes.com/sites/gordonkelly/2014/12/30/802-11ac-vs-802-11n-wifi-whats-the-difference/#6ec777d23957
Dec 20, 2017 | Acer Computers & Internet
Runs slow on video downloads
Hello Sir,
downloading speed depends on internet connection not on PC specification.
If your transfer is low then downloading will also be low.
Take note that source from which you are downloading also must have reliable connection.
cheers,
Mike
May 08, 2010 | Gateway 832GM PC Desktop
s it is ur problem of ur LAN card..check the speed of ur LAN card..
Aug 16, 2009 | Acer 91.AB370.001 Network Adapter
How do i stop the cam from making me look slow when i video cam on msn messager
this problem can be caused by:
  1. your web cam being unable to cope with a high frame rate ( this is unlikely)
  2. your internet connection speed is low
  3. your computer is running to slow to prosses the web cam information
Solutions
  1. if your webcam cant handle high frame rates, then the only solution is to buy a new, higher quality web cam
  2. if your connection speed is low, then close down other programs that use the internet, eg internet explorer or multiplayer games
  3. if your computer is running to slow to prosses the information, then close down any unnessesery programs, for example games, internet, or even word and exell
good luck, please take the time to rate this solution
thanks
Jul 16, 2009 | Radio Shack VGA PC Camera Webcam
Ethernet speed changes from normal to zero
If you have high speed internet go to your ISP webpage and do a speed test. If You are paying for say like 10 MEGS and are only pulling 1.2 Megs. It probably is your modem. Your speed will slow down to approx 7.5 behind a router. Also Your ethernet cable might need replacing. might also might try resetting your router. disconnect all power even the cable comming in and reset everything. Hope that helps.
May 24, 2009 | Apple eMac G4 Desktop
Fiber-optic networking
Apply load balancing of the NIC interface, else put in a switch to interconnect all the computers. That should give equal speeds to all the PC's.....sodeep
Apr 06, 2009 | Computers & Internet
Slow internet.
Your hub can support more that fiber optic puts out. Problem might be a slow computer. Run a internet speed test see what it gets through hub and then straight to the computer bypassing the hub. If possible. If there is a big difference either way what ever is slower is most likley the issue.
Feb 22, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
The modem is extremely slow-most downloads are far too slow
Dialup phone lines usually only transmit a minimum of 8 Baud. NetZero's high speed (5X) faster is done by caching pages you have already visited, not actially running internet but loading pages faster on your computer. Check your modem setting, 56k, 112K are normal speed setting to connect. Check your actual connection speed, 28.8 is probably all that you are getting on dialup.
Feb 01, 2009 | Hiro (H50113) Analog Modem
High Speed and viruses
Slowness can be caused by viruses.
Run a virus scan and see what comes up.
If there are viruses on the computer, you may want to consider Restoring your computer to factory settings.
But before you do that
Run a virus scan; go to Symantec and run it or download AVG free.
If you decide to restore to factory settings, I will be glad to help you. Understand, you will loose everything on the computer, and you will have to run all your programs again, set up your network connection and email. Very time consuming.
Apr 01, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
153 people viewed this question
Top Speed Computers & Internet Experts
Vernon Taylor
Pcm2048
XUNICORNX
XUNICORNX
Level 1 Expert
Are you a Speed Computer and Internet Expert? Answer questions, earn points and help others
