Question about Locks & Locksmithing
Using the keypad to scroll up or down - Locks & Locksmithing
Posted by Marion M C Auley on
How to turn off text clicking
REDUCING KEYPAD VOLUME
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Mark
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
How do i change the code on my schlage BE365. I want to delete my current one and add a new one
You confused me about which model-the FE575 or BE365 lock that you are dealing with, but that's no problem. The information for either can be found on the same page.
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Reprogramming FE575:
Scroll down to this heading on that page:
Electronic Security-Keypad Entry Flexlock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Reprogramming BE 365:
Electronic Security-Keypad Deadbolt BE365
This installation video (second item down) will be useful to allow you to disassemble it and view the sticker.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Jul 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
I forgot my Uniden code to access my answering machine. How can I reset this code?
From the base unit, press the MENU softkey(middle button below the MENU option on screen). Scroll to the ANS SETUP option using the volume up or down keys on the keypad, press the OK softkey. Again use the volume up or down keys to scroll to the SECURITY CODE submenu, enter a 2 digit code(01-99) using the number keypad, press the OK softkey, a confirmation tone will be heard. I have included a link where you can download the manual.
http://www.uniden.com/pdf/TRU8885om.pdf
Feb 26, 2011 | Uniden TRU8885 Digital Answering Machine
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Samsung e1070m keypad tone how to turn off
1. In Idle mode, press <Menu> then profile.
2. Scroll to the phone profile you are using.
3. Press <Options> then Edit.
4. Select Volume, then keypad.
5. Scroll left or right to adjust the volume level.
6. Press <Save>
.Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
Jan 07, 2010 | Cell Phones
Is there any way of turning on the backlight on the numeric keypad on the u600?
From your main menu go into "Settings". Select.
Scroll down to number 5 "Light settings. Select.
Scroll down to number 3 "Keypad light". Select.
It will probably be set to "Night time" 05:00 PM.
Use your direction pad to change it to "Any time" Save.
The keypad backlight will be on all the time.
Aug 17, 2009 | Samsung SGH-U600 Cellular Phone
Can't turn the keypad tone off when i text - samsung tocco f480
You've probably found out by now, but I've been tearing my hair out to solve this and have finally done so today. Menu -> Settings -> Phone profiles. Then select the righthand double arrow icon for the profile you want to change (likely 'Normal' at the top). From the pulldown list at the top right, change 'Incoming...' for 'Phone sounds'. Scroll down to the bottom of the resulting screen (using the lefthand handset buttons if, like me, you have trouble scrolling) and set the 'Phone sound volume' (slider control) to '0'. Then hit 'Save at the bottom, and job done!!! Phew!!!!
Neil J
Jul 05, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
I have a Cable and Wireless Handset and I need to link it to the
On handset:
1 - "Menu",
2 - "System" (scroll using up and down then press "OK" to choose),
3 - "Register" (scroll using up and down then press "OK" to choose),
4 - "1" (use number keypad),
5 - "0000" (use number keypad again - or handset PIN if pin has been changed)
Now on base unit:
1 - press and hold down "Page" until it beeps
Hope that helps
Apr 05, 2009 | Lands Phones
Will not scroll up or down using the pad on my laptop
You may need to install drivers for the extra buttons
available on this page http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=nl&cc=nl〈=nl&product=3192898&
Let me know if that doens't solve the problem.
thanks, Ekse
Nov 11, 2008 | HP Pavilion DV5234US Notebook Laptop
Locks & Locksmithing Logo
209 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
