Question about PRINTER Office Equipment & Supplies
My cp 1000 selphy printer ink catridge was jammed. But when I got it out there is ink paper stuck inside. Help
Posted by Barbara Joan Smith on
Mario Matters
    Welcome Back:
    Visited the website for 2 consecutive days.
How is that possible? The ink cartridges and photo printer are made by Canon for these printers. As far as I know this is supposed to be easy as everything is matched by the manufacturer. I feel like taking my printer that cost me lotsa money and trash it on the counter of the closest Canon service centre. My Selphy CP1000 has not even printed 30 photos yet and the ink cartridge film was jammed today. Pieces of blue and red ink film got jammed and torn off, leaving pieces between the rollers.
Something similar happend with my Selphy CP800, whereby the photo paper would end up going skew n ruining the prints. That printer did not make 50 prints even. I am of opinion that I have bought expensive overpriced junk from Canon. I am so infuriated that I suffering from heatstroke and possible strokes too.
Posted on Sep 11, 2021
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Posted on Jun 12, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Got problem with aficio250
Another thing that can happen to cause a jam when you are printing on there is to make sure that the paper size if correct and matches the trays you are printing to. That condition will happen if the printer tries to print a legal size page and you only have letter paper installed in the trays.
Check your settings in the printer control panel to make sure that the trays match and are correct.
Make sure that the green paper setting knobs match the correct tray size as well.
Posted on Jun 21, 2008
Sanath Kumar V
  • 684 Answers
SOURCE: Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Posted on Apr 29, 2009
lauriejb2006
  • 127 Answers
SOURCE: Color ink cassette stuck in canon selphy
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Posted on Jul 10, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Printer Paper jam
Hello there This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
3helpful
3answers
My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. Printers has a good connection to PC, start to print but after the first paper pass the...
I've just had this same problem with my Sephy 740. Nothing helped until I disassembled the printer and realizing the small gear wheel (not visualized) at position in the red circle had loosened. Remounting the gear wheel on the shaft with a tiny drop of Blue Loctite and letting dry three hours, reassembling the printer and turning it on fixed the problem.
1helpful
Hi, I'm Cecily, and my printer isnt working at all. It says "E" beside the third button down, and an orange light won't stop blinking. I dont know what to do!
It has an Error "E" that's why its blinking orange, Turn it off, check if there's any paper jam inside it, make sure that it has ink and not used up after checking for paper jams and Ink level, remove all paper, make sure nothing is stuck inside it, reseat paper back, make sure ink catridges are reated as they should, close it, then plug it in and turn it on and verify if you still have "E" or blinking.
1helpful
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
6helpful
4answers
CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7...
I had to completely unscrew and disassemble the printer then cut or break the piece of plastic from the removable ink cassette that was blocking it from being removed. See attached pic.1_3_2013_5_05_41_pm.jpg
4answers
Error code 5C00, Canon Selphy DS810
HI..
It means that the purge assembly, thats the cleaning unit where the printhead parks when off on the right, is jammed and cannot move.Look for paper or foreign material stopping it from moving. Sometimes the squeegee unit needs to be pushed back if the pads get stuck under it...
thank u
rate me
1helpful
Ink and paper jam red ligths on ana off ?
Epson Stylus Printer
Please remove catridges from the Printer.
Clean the place with a white cloth along with cleaning liquid in the seat, where the catridges are sitting.
Use genuine Catridges for this Epson printer.
Dust and other things to be removed from the Printer.
Insert the papers in the In tray and check for the paler pulling sensor is working properly.
Paper jam can be taken care, after carefully removing small pieces of papers jammed in the printer.
Finally switch off the printer and machine and reboot the system.
Still problem comes, please contact the local printer engineer to assist you in this issue.
Paper Jam
ya i too got the same trouble
then when i checked it was due to lack of ink in print catridge so u too check for it and switch it off and try later and cancel all prints
Printer problem
Sounds like its indicating a paper jam. Check for anything stuck inside the printer. If you cant see anything - Take the ink out and then turn the printer upside down and give it a real good shake. Put the ink back in and have another try.
2answers
CANON SELPHY DS810 PRINTER PROBLEM
If you open up where you put the ink in, there are rollers that feed the paper in/out of the machine. These may be covered in ink, so just clean them off with an alchahol wipe.
-CGEEK
Top PRINTER Office Equipment & Supplies Experts
Pcm2048
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
