Computers & Internet Logo
Question about Medion Computers & Internet
I have a Medion 11.6" notebook (E2228T) which has 32Gb flash memory and runs Windows 10 - can I add more memory to it? Even an extra 8GB would be of great help!
Posted by Nick Dell'Oso on
5 Related Answers
Anonymous
  • 1027 Answers
SOURCE: Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
Posted on Mar 19, 2008
Anonymous
press the fn key then i think its the f5 key but which ever f# it is it has kinda like wavy lines on it read the instruction manual too it does tellyou
Posted on Mar 31, 2008
Anonymous
  • 400 Answers
SOURCE: How to add extra memory card in the mother board
well u may upgarde your ram to 1 or 1.5 GB if less ... and try installing Windows 7 on your computer i can tell you how to download or if you already have ... then the speed will not bother you any more...
Posted on Jun 23, 2009
Anonymous
  • 118 Answers
SOURCE: Having problems upgrading my GatewayDX4840-11e to 32GB of memory.
Memory Type: DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900, DDR3 (non-ECC)
Maximum Memory: 32GB
Slots: 4
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900 with a maximum of 16GB kit (8GBx2) per slot.*
*Not to exceed manufacturer supported memory.
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
How much memory your Windows OS will recognize depends on which version of Windows you are running. To utilize more memory, install a 64-bit version of your OS.
Thank You
TomMiller
Eng
Posted on Aug 20, 2012
Anonymous
  • 32281 Answers
SOURCE: If I want to add more memory beyond the 8gb max from the MFR, will it work?
You cannot add more RAM that the recommended max. specified by the manufacture.
If you could install more than it 8Gb, either the laptop won't work OR it cannot access more than 8Gb of RAM.
Posted on Sep 05, 2012
2answers
How can i convert 4GB pendrive to 8GB ...?
There is no way of doing this. If your pen drive is 4GB, that means it has only 4GB of memory chips in it. The only way to get 8GB is to buy an 8GB drive. Do not buy an upgraded (to 8GB) one, as they are lower memory ones that have had the firmware tinkered with to show 8GB, when the actual memory capacity is far less.
18.January.2015
How to store program on extsd
Although the Android phones and tablets can add (micro) SD cards, that will not extend the internal memory. You should see the SD card as a extra hard disk. As soon as you installed extra apps, and the phone is telling you the memory is full, you only can free memory, by deleting apps from the main memory.
If you thought I can buy a phone with less memory, because the SD cards are very cheap and will extend the internal memory, you made an error. New phones from Samsung now get more than 10 Gbyte of apps, you even can't remove. So only about 5 Gbyte is free to use for other apps and messages.
Next phone, take one with lots of internal memory, if you like to install other apps.
Medion akoya p6620 loads to windows very dim screen
add duck African PC, Medion
old core2 CPU
2009 made. windows 7 , day 1 new.
the screen is dim all the time and even on BIOS screens?
using the BIOS hot keys for brightness set to max
means./
are bad CCFL backlamps on the LCD array
1helpful
Slots: 4
Thank You
TomMiller
Eng
Black screen, Blinking cursor for 25-30 seconds after HP logo at cold boot.Restarting PC does not add this extra step before windows startup screen. Booting from power off condition has this condition...
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
3helpful
2answers
What is the differeance between iphone g3 to phone gs3?
the main difference between the iphone 3g and iphone 3gs is the speed. but here are the specifications for both phones
weight: the 3gs is slightly heavier at 135g memory: iphone 3g only has two options an 8gb or a 16gb whereas for the iphone 3gs it has 8gb/16gb/32gb camera: the iphone 3g has 2mp camera that can only take pictures while the ihpne 3gs has a 3.15mp camera that can also capture videos cpu/processor: iphone 3g has ARM 11 412 MHz, PowerVR MBX-Lite graphics while the iphone 3gs has 600 MHz ARM Cortex A8 processor, PowerVR SGX535 GPU. So the 3gs is faster and it means less or no lag on apps
the 3gs has a digital compass
and the 3gs has a longer battery time than the 3g.
to summaarize, the iphone 3gs is faster, has longer battery life, and has a bigger memory (as it comes with a 32gb version).
How i fix the erro on my sandsk 32gb but now i can format only have 8.00mb
If you have a USB card reader you can open the card in Windows and tell it to format FAT32. That should give you a full format.
2answers
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
1helpful
3answers
Medion MD-96032
Are you able to see the screen as if just the back lighting is turned off?
Top Medion Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
