Cars & Trucks Logo
D
Daniel Posted on Jan 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the blower motor resistor on a 1992 Lincoln continental signature series located?
  • Daniel
    Daniel Jan 01, 2018
    Yes it is
  • Rick M
    Rick M Jan 01, 2018
    doesn't have a resistor. Blower motor controller
Jeff Armer
Level 3:
  • Lincoln Master 15,575 Answers
  • Posted on Jan 01, 2018
Jeff Armer
Lincoln Master
Level 3:
Answers
15575
Questions
Helped
7100646
Points
73899
Doesn't have a relay , blower motor is controlled electronically by blower motor speed controller an the EATC control module . B+ voltage from fuse # 9 30 amp ,location fuse panel ,feeds B+ voltage directly to the blower motor .Here is a web site for free wiring diagrams http://www.bbbind.com/free_tsb.html Enter vehicle info. Then under system click on HVAC ,then under subsystem HVAC controls will pop up on it's own . Click the search button then click the first blue link . Scroll down to the second diagram .
  • 1 more comment
  • Daniel
    Daniel Jan 01, 2018
    Would that cause me to only have high when the heat is on?
  • Jeff Armer Jan 01, 2018
    The controller probably .
  • Daniel
    Daniel Jan 01, 2018
    Thank you I appreciate it
Rick M
Level 3:
  • Lincoln Master 4,148 Answers
Rick M
Lincoln Master
Level 3:
Answers
4148
Questions
0
Helped
1252400
Points
13941
Variable speed blower?
  • Daniel
    Daniel Jan 01, 2018
    Yes it is, Lincoln problem
5 Related Answers
Anonymous
  • Posted on Feb 01, 2009
SOURCE: locating heater blower motor resistor
the resistor is behind your glove box. open the box and push in the sides to release it and let it hang down...the resistor is right there. I didn't try to replace it, a friend did it, but the part was under $20.
Anonymous
  • 4 Answers
  • Posted on May 30, 2009
SOURCE: have to change blower motor resistor where is it located
Located behind glovebox. 2 screws and 2 plugs. very simple
Robert Debison
  • 412 Answers
  • Posted on Jun 12, 2009
SOURCE: help with location and replacing blower motor resistor
depends on what year van..1996-2000,located in engine compartment just above right strut tower at firewall..2001-2007..located behind glove box
Anonymous
  • 62 Answers
  • Posted on Aug 01, 2009
SOURCE: blower motor resistor location on a 1996 gmc 1500?
It is located on top of the heater box in the passenger side remove the glove box to gain acess there are two 7mm srews and a relay braket holding it in place it is a tight squeeze but can be removed with a 1/4 inch ratchet.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Oct 06, 2009
SOURCE: 2002 Lincoln Town Car AC Blower Motor Relay Location
Relays are normally located under the hood in a protective plastic box. Good Luck Ned
2answers
1994 lincoln continental heater switch stop turning on the blower
Does AC come on? that would eliminate the blower motor & fuse, The most common problem is the relay or switch. Start by cking the fuse.
How to replace blower motor resistor relay on a 2001 lincoln continental
A resister and a relay are two different things, so do you want to replace one or the other or both. And are you sure that this is the problem. The resistors for the heater are always located inside the air duct from the fan, and generally there is a cover plate over them so you can gain access. Look under the dash in the heater ducting. I cannot help you with where the relay is located.
2answers
What is the weight of a 3.8 liter engine .
thats depends on whats attached but you can remove it from car with a 1000 # lift if that's what your asking
hope this helps mike
Where is my blower motor resistor located on a
Hi Carlos,here's a link to your blower motor,the resistor is located next to the blower,2 screws hold it on,just remove electrical connector and screws and take to Autozone and match up,very easy to do. GET 25 GIFT CARD FOR EVERY 100 SPENT ON ONLINE SHIP TO HOME ORDERS Here's the part. Heater Blower Motor Resistor at AutoZone com Best Heater Blower Motor...
1helpful
How do i get to the blower motor resistor
it is located on the heater box where the bolwer moror is there will be two screws holding it on the housing, look on the passenger side under the dash it will have 3 to 5 wires connected to it depending on the type of temp controller.
Blower motor not working checked fuses are ok
The resistor is bad. or th blower motor itself. check the resistor first. it is located in between the wiring and the blower motor. it is a small gadget. Not an electronic resistor. usually under the dashboard.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
