SOURCE: tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
SOURCE: Horizontal White Line
In your statement i found during switch on you get picture. Check whether in a few minute picture suddenly goes to the horizontal line or height reduces and then goes to line. If suddenly goes means change any zener diode in pumpup circuit. If it is not means LA 7840 ic getting imbalanced supply voltage i.e.,negative and positive voltage are not equal. Suppose only one vcc means supply resister getting high ohms and change the the supply resister.
SOURCE: vertical line in center have replaced vertical output ic
If the line is vertical then the problem is no horizontal deflection. The vertical chip is probably fine.
Check connections around yoke (thats the connector with at least four wires that goes up to the coils around the neck of the tube)
Maybe that TV has two horizontal output transistors. One for deflection and one for high voltage? Check both of them. Look for bad solder joints!!!
SOURCE: panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
