Question about Yamaha Electrical Supplies
Powermate yamaha atg 5700 7125 generator pm0675700 serial # f24001422b. dog chewed wires from the wire harness next to oil fill. need a color coded chart to reconnect wires
Posted by John K Shields on
5 Related Answers
Anonymous
  • 95 Answers
SOURCE: color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Posted on Feb 21, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Posted on Apr 06, 2009
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
Posted on May 16, 2009
Anonymous
SOURCE: wiring diagram or color chart for a 96 ford mustang radio harness
dont even worrie about it just go to walmart or an auto parts and get a wiring harness they are not so expensive
Posted on Sep 06, 2009
Generators. a dog chewed wires on the oil fill side from the harness on my powermate 5700 7125 pm0675700 serial # f24001422b. i need a color coded wire chart to reconnect wires. s
Why not order a new harness here is manual with parts list you can order harness from powermate directly
There is no wiring diagram in manual
www.powermate.com
Manual https://www.dropbox.com/s/k4w4e3huikl99pa/manual_pm0675700.pdf?dl=0
if you send pictures of harness i may be able to help also the best way to figure this out is to get socket at other end of harness loose if possible and inspect this end to get wiring pattern for other end of harness...send pics if not sure
Dec 30, 2017 | Cars & Trucks
Need image of where the wires go on a powermate 5700 generator with yamaha motor. the wire colors are yellow,blue,black, and black with white stripe
are these wires on the engine only ? if so they could well be from the low oil sensor, maybe over heat sensor and to the kill switch if this is the case then its possible that they connect in a chain from kill switch to earth which will shut down the engine if a fault develops
Mar 09, 2014 | Powermate Portable Generator 5700 Rated...
I need a wiring diagram for my powermate 5700? Do to my dog chewing off the wires
you need 2 replace the dog...! (BEFORE THE WIRING job) ...that's a really tight spot they're in....
HE'LL SEE NEW WIRES AND SAY....
OH GOODY....I bet he'll like this ! that's what he gets for leaving me home alone ....i'll show HIM !
Mar 08, 2014 | Coleman Powermate Powermate 5000W...
Hello, Im trying to rewiremy transmission on a 92 GMC 3500 vandura box van. My don chewed the wiring that plugs into the transmission The plug has 11 wires coming out of it but some of them that he didnt...
Hello tnvolsfan32,
Use the FREE drawing available on the
BBB Industries site to trace out your wiring...
BBB Industries Premium Alternators Starters Power Steering Products
First put the wires together that
DO PERFECTLY MATCH... Then go
back to the drawing and find out what
DEVICE, CONNECTOR or PLUG got
disconnected or swallowed.
Generally wires DON'T CHANGE COLORS
in a wiring harness run... So you definitely
need to look for a LOGICAL EXPLANATION.
Registration is required... these are real
wiring documents...
Each time you return from a WIRING page
make sure you have not
defaulted back into TSBs...
(technical service bulletins)... While usually
quite useful... they don't begin to address any
WIRE-EATING-DOG problems...
If you get confused comment me back...
I can recommend some great tools to help
SPLICE everything back together
Tone Tracer being PRIMARY
Extech TG20 Wire Tracer and Tone Generator Amazon com
Helpful hint: wire must be ISOLATED to trace correctly
(pulled fuse or chewed through works).
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | GMC Cars & Trucks
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
[email protected]
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Dogs chewed what i think is the oil sensor cable but i cant find a diagram to know what it is exactly.
the oil sensor goes right to the on/off switch...see which end is cut...and reconnect it to it...
[email protected]
Jul 09, 2009 | Coleman Powermate Powermate 5000W...
No spark
If the dog chewed up the coil wire you will need a new coil. How did the dog GET to the wiring? Did you let the dog live? The wires are color coded. Splice the wires color to color. Depending on how badly the dog tore up the wires, you may want to get a new, (or used) wiring harness and re-wire the bike following the pattern of the existing wiring.
Please rate this solution as "FixYa" if it has answered your question.
Mar 25, 2009 | 2004 Kanuni Tigrina 100
Hello I have a coleman powermate 5000 that i need a wiring diagram for the brigg and stratton moter some of the wiring has be destroyed and i need a diagram to get it back running can you help me PLEASE....
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Dec 03, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
271 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
