Question about Hotpoint Refrigerators
Hi I have a Hotpoint HM312I fridge freezer 70/30 split. The fridge is hot plus 12 deg C and the freezer appears ok at approx minus 18 deg C, but building up ice.
The compressor runs all the time, no breaks. The door seals are ok. The thermostat has been changed about a month ago. The drain in the fridge is unblocked. Any ideas guys n gals?Currently defrosting it.
Posted by Strengar on
Melissa Martin
    Master:
  • Hotpoint Master
  • 753 Answers
Most likely the evaporator fan motor, do you hear the fan running in the freezer section?
Posted on Jan 01, 2018
5 Related Answers
Shaf Ahmed
  • 139 Answers
SOURCE: Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Posted on Jan 11, 2008
Anonymous
SOURCE: Can not get temp. below +10 f
what is your superheat and is defrost cycle working
Posted on Feb 28, 2009
Anonymous
  • 531 Answers
SOURCE: fridge not cold - freezer cuts out at minus 10 degrees.
check damper control
Posted on Apr 03, 2009
stephanos18
Steven White
  • 144 Answers
SOURCE: Ice in my fridge
Without seeing this I can't tell you a price or exact fault but the first free thing to try that could likely fix it. unplug the unit from the power and leave both the doors open for 48hrs so the unit is 100% defrosted then try again. cheers.
Posted on May 31, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: I have amana bottem freezer,1 month ago i
Hello, Unfortunately the compressor likely is seized now. There are a couple of reasons that the original start device failed, 1) faulty connection. 2) poor quality part. 3) compressor was running non-stop due to other deficiencies in the unit or 4) the compressor was failing to begin with. The compressor may indeed check out ok as far as electrically ( windings ) but the mechanical component ( rotor ) has locked/seized up. You can determine whether it is the windings by checking the ohm value between common to start, common to run and run to start ( c-s, c-r, r-s ) and look for values similar to 6ohms, 3ohms, & 9ohms. Then check the start and run & common windings against the compressor casing to see if windings are shorted. In order to double check the mechanical component you'd need another hard start, ( or a test cord direct to 120vac, but that should only be done by an experienced tech ). nothing else will start it at this point obviously or you wouldn't be using a hard start already. The other unfortunate issue is this, many of these compressor's have a 10yr. parts only warranty but that was voided as soon as the 3in1 hard start was installed. In the end I'm likely not telling you anything you didn't already suspect or know in fact, but it is likely the compressor. I sympathsize, seized compressors **** ! Hope this answers your question and moves you forward. good luck macmarkus :)
Posted on May 08, 2010
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Why is my upright fridge freezer bleeping constantly, both fridge and freezer cooling ok
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Srl629ev refrigerator
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge.Otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | Refrigerators
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Candy fridge freezer seems 2 be running ok.....but freezer only does -minus 10...fridge plus 14.....back of item is nice and clean.......?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Candy CPDA241 Top Freezer Refrigerator
How cold should my freezer be?
zero deg F. or -18deg C. for household Fridge freezer.
Deep freeze, like a chest freezer, - 10 deg. F. -23 deg. C.
Household freezer storage is good for approx 3 - 5 months depending on product.
Deep freeze storage is good for 2-3 years, again depending on product.
Jan 15, 2011 | Refrigerators
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice in my fridge
May 31, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
196 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
