Question about Zephyr Kitchen Ranges
I have a zephyr savona zsa- m90s range hood that is making alot of noise when operating on medium range. the unit is 12 years old should I replace the fan motor at this time
Posted by Bucky Sheats on
3 Related Answers
Anonymous
SOURCE: Zephyr Savona Range Hood only speed 3 works
had same problem (w/in a few months)
switch assembly poor design
thay sent a replacement (i put it in)
seen other complants
Posted on Jul 20, 2008
HandyTxDude
  • 37 Answers
SOURCE: need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
Posted on Jan 03, 2009
Anonymous
  • 68 Answers
SOURCE: range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Posted on Feb 06, 2009
Zephyr Savona has blue blinking light. What does that mean?
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
3helpful
Blower doesn't work
It is not the blower. I had my electrician come out and check the unit out it is the Switch Assembly. Part # LAA003-00000 but I am having a hard time finding a replacement. Please let me know if you have any idea's
Replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at [email protected]
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
3helpful
Light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
4helpful
Need to change lightbulb of Zephyr Savona Zsa-m90s
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
How to install the ventless Zephyr ZSA-M90AS
Here is the link that has the rough in you need pls review me. Thanks
http://www.zephyronline.com/docs/brand_essentials/products/manuals/savonaa_manual.pdf
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Kitchen Ranges Logo
Top Zephyr Kitchen Ranges Experts
Dale Copeland
Dale Copeland
john h
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
