Upgrade what?
from what to what. w7 to 10? what?
seems w8.1 to w10? came with both new, {OPTIONAL
what stream there are 18 models of stream.
i cant guess them at all , must be said.
there are 4 , Pro 11's in fact.
ever heard of HP.com? the company
they made it and the support page is here.
for touch pad for sure, called input devices on the software page.
ill do wild guessing, lacking your service tag data.
example, w10 64bit now.
https://support.hp.com/us-en/product/HP-Stream-14-Pro-Notebook-PC/15932849/model/15932850
are you internet connected?
be so
then in device manager. (CP)
click on the mouse pad driver there and click update driver yet?
if that fails
you need to load HP drivers, to make it work.
or just run the HP support assistant.??
http://h18021.www1.hp.com/helpandsupport/hp-self-support.html
SOURCE: Touch-pads unresponsive
Some newer models have a child lock feature which can be accessed via a HELP or CUSTOM HELP pad. On recent LG models, try pressing the "0" key for 5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Has anyone ever sprayed cleaner directly on the keypad? Has anyone ever boiled on the stovetop without running the hood vent fan? Is the hood vent clogged? Any of these can cause moisture buildup on the control circuit board or in the keypad, which can cause odd problems like this. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Please let me know if I can help further: http://tinyurl.com/yzjozk
SOURCE: touch pad
You probably fried something with the coffee. There are replacement touchpads available if you know how to replace them if not an authorized dealer will be able to point you in the right direction.
SOURCE: touch pad not working properly
That sounds like the interface controller which is just a little computer chip that cotrols everything and watches the signals from the touchpad is having problems. Usually these will behave like this and then just stop so your touchpad is totally dead. It may take out the time displays as well.
If you have warrenty from GE or the store it will be covered. If you are not covered then it can cost about the same or more as a new microwave as they will have to replace the board. Check your warrenty's, then check the repair cost and check replacement costs. Usually a new microwave is the cheapest.
SOURCE: My MacBook Pro is unresponsive.
If this is a brand new macbook and you have not been familiar with them before....be aware that the whole touchpad is clickable by pressing it down. You can also go into your settings, under the mouse applet and choose to enable the tap to click rather than pressing the button.
SOURCE: HP dc5000 compaq - running win xp pro sp2 and it won't upgrade to sp3. Sp3 needed to run Nero 11.
go to this link http://www.microsoft.com/en-us/download/details.aspx?id=24 download winxp sp3 exe follow instructions disregard for IT professionals and developers this is the download you need after installing goto windows update and download and install updates
