Question about Maytag Refrigerators
MAYTAG MFI2569VEM2 The ice has stopped making ice what should I do?
Posted by Paula Petzold on
Greg Cunningham
  • 7 Answers
Check the water line.. the full ice arm..or may just need.new.ice maker
Posted on Jan 02, 2018
David Emmel
    Sergeant:
  • 295 Answers
Https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
2 Related Answers
Henry Russ
  • 31 Answers
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Posted on Feb 07, 2009
richroth
Richard Roth
  • 9472 Answers
SOURCE: maytag ice 2o mfi2568aes ice maker will not stop making ice unless turned off
What is the part number on the ice maker?
Posted on Dec 07, 2012
Turning off the ice maker on my may tag refrigerator freezer
Hello, Suzanne -
Most ice makers in refrigerator / freezers have a heavy metal wire "arm" which activates and deactivates the ice making process. When the "arm" is in the down position, ice is made.
With most refrigerator / freezer ice makers, the "arm" can be set in the up position, so that the ice making process is stopped.
See information here:
http://www.acmehowto.com/howto/appliance/icemaker/check/shutoffarm.php
Best wishes.
May 08, 2018 | Maytag Refrigerators
Www maytag ca
Try removing the ice maker and give it a thorough thawing out and then reinstall. (Reboot LOL)
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 27, 2018 | Refrigerators
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
Maytag MCD2257KES ice maker shoot door does not open
Yes, the ice/water unit can be removed from the door to give access to the switch and solenoid that opens the ice door.
Dec 28, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
120 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
