SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
SOURCE: oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Please rate my solution.
Thanks.
SOURCE: fan and grill works, grill actually cooks but oven
Without a doubt this is the element that is faulty.
It is located at the rear of the inner oven compartment behind a removeable cover.
