SOURCE: universal remote
Codes for Panasonic TV.....171,148,054,170,062,374,381,437,003,070. You can Goggle the programming info...Just ask...How do I program a GE Universal Remote... There are about 7 steps...easy if these codes work....good luck...I have a remote that none of the given codes are working........
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
SOURCE: I have an GE universal control model #RC24914-E
Search online (google) they are available for download, usually free.
SOURCE: Direct Entry Code for GE television for GE RM24911 Universal Remote
NECESITO HOJA ADJUNTA DE CODIGOS DEL RM24911 POR FAVOR
SOURCE: i have lost the ge universal remote guide for the
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
