Question about LG Washing Machines
LG TOP LOADER how do I remove lid on model WT4870C ?
Posted by John Burdette on
Sal De
  • LG Master
  • 2,699 Answers
Https://www.google.com/search?q=how+to+take+apart+lg+top+load+washer&oq=how+to+take+apart+lg+top+load+washer&aqs=chrome..69i57j0l5.12786j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Posted on Dec 31, 2017
  • Sal De Dec 31, 2017
    copy and paste
  • Jack Graham
    Jack Graham Jul 04, 2019
    This does NOT answer the question.
robert
  • LG Master
  • 2,535 Answers
The lid has hinges on the back so it rotates back from the front. The front is held in place but two metal clips. Push a metal spatula in the seam between the top and front to release the clips. Clips are about 1/4 in from each side.
Posted on Dec 29, 2017
4 Related Answers
Anonymous
SOURCE: kenmore elite washer lid removal?
how do i remove the washing machine the top
Posted on Nov 04, 2008
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Posted on Apr 18, 2009
john_cross
  • 6277 Answers
SOURCE: I have an LG WF-T7050TP
Sorry but this forum does not supply parts, part numbers, costs or other details direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 03, 2011
Testimonial: "Thankyou for the reply ,it was very helpfull "
some1cares_m
Jorge Rendon
  • 5420 Answers
SOURCE: Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Posted on Mar 24, 2015
No lid lg washing machine model wf t507 top loader were is sensor to make wash without lid
Appears that the lid originally had a magnet on the right side. So you can try to use one on the sensor that was activated by it.
Nov 18, 2014 | Washing Machines
Top loader LG fuzzy 8.2kgs wf-8071ttp showing dE. Error. What could be the major fault
all top loader washers have a lid switch so machine will stop when lid is raised,on the inside of the lid the is mounted a small plastic cover with a magnet inside which activates a switch just under the top of the machine if the magnet is gone thats your problem,if still there then switch is faulty
Sep 29, 2013 | Washing Machines
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
How do you remove the top on a LG WM2077CW front loader?
I can not remove the top cover of my LG WM-2277HW
can somebody tell me how to lift off the top cover. I already
removed the screws from the rear
Nov 09, 2009 | LG WM-2277HW Front Load Washer
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Kenmore elite washer lid removal?
Oct 20, 2008 | Washing Machines
Whirlpool Top loader
Open the lid and the model and serial tag is on the washer itself in the middle under lid in back. Open lid and look at area where lid and washer top come together between hinges.
Nov 05, 2007 | Whirlpool LSB6200KQ Top Load Washer
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
1,348 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
