SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
SOURCE: 26" TV is inop
repost
Gateway was sued Class action over LCD's and Plasmas they sold over a 2
year period. They resell 3rd party TV's that were very faulty, an
immature design.
Here's what I learned about mine, which makes it limp through as a
Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input
there is an option called "Factory Mode". scroll down to it with the
CH buttons and select it with the vol button. The scroll to
"initialize eprom", select and confirm it. After the "Waitting" words
disappear, make sure you have a TV source connected, Then turn the TV
off and on, using the hard switch in the back. The TV input should be
defaulted to channel 10 or 11 now But you select a TV channel that has
no TV signal on it (like channel 1 for example) , the whole TV input
side will refuse to let you select it again, and you'll have a blank
screen and have to start over.
That takes care of the blank screen thing Now the other problem is
parental control is defaulting to "ON" or something, and you can't
program channels. With the TV input Main Menu engaged, select "Setup
Menu." If you have this problem, then you'll only see 2 options, all
the TV input and channel programming options will be missing. You have
to select Parental Control, and when it prompts you for a password hit
the volume > button 4 times (or just wait for a minute.) This
should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I
select cable, it does better if I select "AIr". But at least it
funtions - kind of. If you switch to your computer input, you probably
will have to switch the monitor off and on from the back panel again.
Mine always starts up with the menu onscreen. All this might bve less
trouble if you have a the remote, I don;t know where mine went after
the last move.
Good luck, and hope this helps.
Billy K.
SOURCE: philips model 29pt3425-79 flat screen wont switch on
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
SOURCE: no power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
SOURCE: I have a Toshiba model 32WLT68,which will not switch on
Have the main power supply module checked out first.
