Question about Measuring Tools & Sensors
SOURCE: After receiving the 2.2 android
A rule to updating firmware is " If It Ain't Broke Don't Fix IT!"
What you can do is roll back the update to the previous edition.
Posted on Aug 12, 2010
SOURCE: I have installed the software
This particular product seems to have a common problem of not working properly. Customer support is poor. It is buggy and many customer complaints that it does not connect to internet to download data and should it connect, does not automatically update. Try checking your firewall settings. Go to control panel and click firewall, advance, and add the website url address where the information is being downloaded from. Also go to Control Panel, Internet Options, Security, Trusted Sites, and add the website url address, apply, and save.
Posted on Jan 06, 2011
SOURCE: Software for Weather Station EC-WS115
reguire driver/software for ec-ws115 wireless weather
Posted on Dec 16, 2012
SOURCE: Doesn't receive weather updates from the internet! Has not updated information in two days!
I think there's a problem between acuweather and bushnell. We may simply have to realize we useless equipment. Hey, my calendar is still working so I know that date!
Posted on Apr 12, 2014
If you have a Sharper Image ES-WS115 five day forecast weather station I believe have found a way to return it to service. I picked up a unit at a local thrift store that was still brand new in the box with only the owners manual missing.
The manual is available at
https:/www.manualslib.com/manual/783137/sharper-image-ec-ws115.html
Unfortunately the installer program on the CD only directs your web browser to a server that no longer exists to download the program to your PC.
After considerable searching the web I suspected the manufacturer of this product is NSHnordic.com. I found a similar product of their Ventus model W194 4-day forecast weather station. At this point I was willing to forego the fifth day if it would at least give any functionality. I downloaded their installer program for the W194 fromhttps://www.nshnordic.com/english/suppor...
This installer did download the program to my PC which easily installed.
I found that I needed to reboot for the program to load at this point.
If you do not see the user interface and after clicking the "4-Day Forecast" icon, get the message "This program is running on your computer", I start the Task Manager (Control/Alt/Delete), select the "Processes" tab, then select 4-Day Forecast.exe and then click the "End Process" button. Now when you start the program the user interface will display the first time you restart the program.
Once the program runs you should see the user interface and select the "HOME WEATHER" tab at the top then setting... button at the bottom. then click the "SET LOCATION" button make you selections then the "SAVE" button. Then select your preferences for Temperature, Wind speed, Time format, etc. Then click the "Save" button. At this point the program should display the current weather data. It's important you set-up the "Home Weather" as this is the data that will be sent by the transmitter to the main unit's display.
At this point I had trouble getting the weather data to transmit over to the display unit.
I wish I knew exactly what I did that finally worked but here are some of the things I tried.
1. Pressing the button on the bottom of the transmitter forces the unit to send data.
2. Disconnect the transmitter from the USB port, remove the batteries, wait a few seconds, reinstall the batteries, use a straightened paper clip the depress the reset button thru the small hole marked "R" visible with the battery cover removed near the "CE" molded on the bottom.
3. Uninstall and reinstall the program. This requires resetting your location and preferences info again and may require a reboot.
The data did slowly transferred to the display so give it a few minutes.
Happily, despite the software being designed for a 4-day forecast unit, I am getting all 5 days populated with all appropriate data.
Be persistent and good luck.
John
