SOURCE: canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
SOURCE: Describe your canon imagerunner 1023 how to
1) on copier you have a button add. functions-something like *
2) with + or - trough the menu press OK at FAX sett. or under report sett.- If I recall its under Fax sett.
3) try to find report sett. then OK
4) you must enable the RX REPORT than OK
For transmision report you must enable TX REPORT
SOURCE: Describe how to remove hard drive from canon
what you will have to do is remove the back cover.
then you will need to remove the thin metal cover laying flat cover on the back half of the copier just under the doc feeder. should be 3 screws.
then there is a metal box that holds the main controller on the right. if you open that you will see the IDE cable which will run up and out of that box and will run up under a thin metal plate that should be held in by 2 screws. if you remove those screws you should be able to see the hd .
if you can't get it out and or find it please call me it might be easier to explain. over the phone.
C & S Canon Copier Repair
(858)414-8475
Testimonial: "I was able to find the HD and now I am going to replace it. Thank you very much for the answer it was very helpfull. I even call the tech and he helped me out over the phone. FixYa I think you are doing a great service!!!!!"
