Question about Icom Radio Communications
Icom M700pro. The S/FR Meter, 8 bar graph is always on.Does not move in receiving and transmitting. I reset the CPU , no difference. Anybody know why? thanks Harald
Posted by Harald Wilsch on
Clint Millett
    Habit-Forming:
    Scholar:
  • 97 Answers
Try adjusting your RF gain control. This will often cause this to happen if it is fully on.
Posted on Nov 10, 2019
5 Related Answers
Anonymous
SOURCE: problem transmitting
hi there!
i bought the same pair of motorola, and i hav the exact same problem
i found out that they work good only when they are on the same channel but the sub channel must be set on 0.
for example channel 22 sub channel 0 .
Posted on Apr 28, 2008
Anonymous
SOURCE: Meter Shows Signal, no noise
when you have no RX or TX at the same time, that most often means the pre-driver audio transistor is bad.
Thanks,
Dodgem
http://dodgem250.angelfire.com
Posted on May 08, 2008
Gavin93
EDACS
  • 66 Answers
SOURCE: Icom F21
It's a frequency error. It can be corrected, just give me some time, I need to figure something out first. It might take me a day or two.
Posted on Sep 07, 2008
Anonymous
  • 22 Answers
SOURCE: swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
Posted on Apr 23, 2009
barney2xbass
  • 9 Answers
SOURCE: Icom IC-2100H Sqealing
The squeal in this model is a famous problem. If you look at the circuit board, you'll see there are a few places where it looks as if someone kinda forgot to put in a ground screw -- even to the point that there are threaded holes in the casting just begging to be filled by the little screws used elsewhere nearby. Take 3 or 4 similar screws, put them in the remaining holes, and make sure all (including the existing ones) are snug. It seems there just weren't enough ground points for all the RF swirling around on the solder side of the board, so there's a bit of RF feedback on this radio. And as long as you've got about 16 amps of clean DC, you're fine; the power leads are correctly fused at 20 amps. BTW, the power amp module in this model is really only spec'd at 144-148; if you're running an odd "MARS or CAP" split, the PA brick can get way unhappy. HTH, -- Barney --
Posted on Jan 03, 2010
I'm looking at buying a icom f6061, what's the max power I can get out of it?
Hi Jamie, max RF power output on Icom F6061 is 45 W. Do you need any other info or help with finding a distributor for purchase?
J.
Jan 03, 2017 | Radio Communications
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
I can transmit to my to my baofeng vr6 but i cant reiceve a transmit from it to my icom v85
Check the input output settings.
the baofeng is notorious for being somewhat difficult to program manually.
Try the software setup if possible.
Jan 16, 2014 | Icom Radio Communications
Not receiving
Hello
I understand this ICON 802 marine radio will not receive.
There are two things to check for. First check the speaker jack on the back side of the receiver also check the speaker plug and the connections. Make sure that the wires are soldered properly. If you have access to an ohm meter connect it to the plug leading to the speaker, it should measure 4-8 ohms. If the speaker checks ok then check the headphone jack on the front panel. The jack has a contact switch internality to disconnect the external speaker whenever a headset is plugged in. You can clean it by using a electronic contact cleaner spray a little into the jack and plug in a headset and turn the plug back and fourth. If this doesn't work, it would be inside the unit itself.
Hope this helps
Bruce
Dec 21, 2013 | Icom Radio Communications
ICOM 802 NOTRECEIVING
Check the speaker .it may be busted. If you hear any sound your receiver circuit is faulty
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
Icom 756 transmit but signal meter goes back to zero and showing no rf output.when i key up there is a signal on the built in spectrum i have reprogrammed the radio as stated in the manual but still n
am not 100 sure has have not worked on this model but maybe there is some sort of fuse, "or bulb used as a fuse lie in the old yaesuft-747gx" near the rear output if not loo at the copper tracks on the board around there, and trace back.
Dec 28, 2012 | Icom Radio Communications
Icom IC-M34 transmit correct but do not receive if sql is above 0
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Mar 13, 2011 | ICOM Informatique Floating Hand Held Vhf...
I have an Icom-M700 pro, serial number2404380 installed on my yacht. I entered in set mode and probably did something wrong because since that moment the radio only transmit in AM and FSK mode. I am now in...
Under some circumstances the transceiver’s internal
CPU may cause erroneous indications on the display.
If this happens, reset the CPU as follows:
While pushing [ENT] + [0], push [POWER] to turn
power on.
• The CPU is reset and the display at right appears.
CAUTION: Resetting the CPU returns set mode
contents to their default values.
that's the quickest way to do it, hopefully you don't have alot of stored frequecies in memory.
you can get a pdf copy of the manual here
http://www.icomamerica.com/en/products/marine/ssb/m700pro/default.aspx
robert
Oct 21, 2009 | ICOM Informatique M700Pro (150 Channels)...
Radio Communications Logo
137 people viewed this question
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
