Question about Dual Audio Players & Recorders
I have a sanyo srs Model # awm 2000u. Its a dual cassett player recorder, with cd player, am/fm radio. I need to know what the replacement cost is?
Posted by M E Tanner on
5 Related Answers
Anonymous
  • 83 Answers
SOURCE: car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at [email protected] hope this helps you
Posted on Jul 12, 2007
alex Martin
  • 71 Answers
SOURCE: Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Posted on Nov 27, 2008
Toyota Ed
  • 1861 Answers
SOURCE: Toyota Previa 1993 AM-FM Cassette Unit Model 11709
Send me the code for the radio, I have all of the unlock codes.
Posted on Dec 08, 2008
Anonymous
  • 44 Answers
SOURCE: Honda Radio button lights do not illuminate
were the lights working before?
sounds like a defective radio.
Posted on Dec 19, 2008
Anonymous
SOURCE: to install sony car cd/mp3 player removing the FM cassette player
how to connetct stereo system
Posted on Apr 13, 2009
Will it record on most cassette types
The difference between cassette types is the length of the tape and the quality of the tape. Your recorder will work on all types of cassettes.
Dec 17, 2015 | Panasonic RX-D55GC-K Boombox - High Power...
Can i connect an external antenna to a sanyo awm 2000u stereo for better tuner reception?
Your stereo came with a piece of wire attached at the back. This is/was the FM aerial. It should be roughly 1 metre or approx 38" long. There is no socket on the back of this stereo to attach an external FM aerial. So if the wire broke off then you're going to have to either attach some new wire to the stub, or open the set up and solder directly to the circuit board.
The exact cable lengths for an FM antenna to pick up 88-108 MHz is 37.66" long.
Sep 12, 2014 | Audio Players & Recorders
Where is the CD port
Only the RAZ model had both a CD and cassette player built-in. There is a small white 3 letter code on the radio, starting with an "R" - what does your radio say?
Dec 06, 2013 | Chrysler 2001 PT CRUISER Radio a1z111345...
Rewind button on Coby broken - how to replace
nesecito el picki-up laser lens para un boombox coby modelo mpcd 450blk [email protected]
May 22, 2012 | COBY-PERSONAL & PORTABLE Coby Mpcd450...
Cassette player doesnt play or record, ff or rewind. CD player, AM/FM radio works fine.
Hi.
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
Jan 14, 2011 | Memorex MP3227 Radio/Cassette/CD Boombox
I have a Sanyo DVD Player Video Cassette Recorder DVW-7100A and had broken the remote. I would like to know what it would cost to purchase another one.
I have a sanyo dvd player/ video cassette recorder model no. dvw 7200 and would like to buy another one dyou have any suggestions as to where I can find one
Jan 20, 2010 | Sanyo Televison & Video
Cassette adapter and MP3 not working
Usually a dirty tape head. I recommend adding a 3.5 jack to your radio through an fm modulator.
Apr 24, 2009 | Sanyo FXCD-500 RB CD/Cassette Receiver...
Jun 29, 2008 | 1993 Toyota Previa
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
