Question about Food Processors
Is ther an way to take apart the rubber seals on the lid of my fp12 dc food processor to clean
5 Suggested Answers
ukvacfan
Ryan S
  • 328 Answers
SOURCE: Broken food processor lid
Check EBAY UK for any older models = you might not be able to get the lid on its own - Moulinex parts are difficult to come by unless they are still being made. Failing that visit UK shops such as Cash Converters or similar - you can sometimes find these food processors there.
Posted on Jan 02, 2009
Anonymous
  • 137 Answers
SOURCE: I need a new 6 cup holder and lid for my GE food processor.
Try these URLs
www.abtecparts.com---www.marbeck.com---www.smallappliance.com---www.nelsonappliance.com
Posted on Mar 02, 2009
Anonymous
SOURCE: need a replacement part for food processor
The motor is runing, but the blade is not turning.
Posted on Mar 18, 2009
ukvacfan
Ryan S
  • 328 Answers
SOURCE: broken blender jug for breville FP12
Hi Contact Breville customer services on:
http://www.breville.co.uk/contactus.html
Either phone them or email them - they should be able to sort you out with a replacement jug.
Posted on Mar 30, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: need bowl and lid for 5100
Go to this site. or type magicmix in the search bar at the top of the screen, Good Luck
http://www.magimix-spares.co.uk/Parts-for-Magimix-5100-lid,-...
Posted on Oct 31, 2009
How do I clean the lid on my Cuisinart diecast 12 Cup food processorlittle pieces of foods such as chopped garlic and seeds get stuck underneath the seal and there is no way to take them out?
This isn't actually to hard. Take a small straight screwdriver and VERY carefully prize the rubber seal out from around the edges. You can easily remove it then wash dry and put it back in place,
Oct 01, 2014 | Food Processors
Rubber seal for bowl of Ovatio 3
contact an appliance repair shop or the maker direct on line for the part. Go to a rubber supply shop and ask for food grade rubber and cut your own.
May 26, 2013 | Food Processors
The magic bullet lid rubber ring has broken. Can I
When you received the bullet it should have come with extra rings. If not you can probably get more on ebay.
Dec 30, 2009 | As Seen On TV Magic Bullet Food Processor
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
The top cover is broken where the lid makes connection with bowl
I think you will have to look on your user manual at the back and see if you can find an adress there, I think you may have to write to them and ask them for a replacement lid?????
Apr 10, 2009 | Food Processors
Broken blender jug for breville FP12
Mar 28, 2009 | Food Processors
The top lid has a plastic round piece that connects to a rubber
Doug; Type in Bravetti in the search bar and you can find resources to find the gasket. good luck
Jan 24, 2009 | Bravetti Quad Blade Food Processor
Need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Dec 07, 2008 | Cuisinart DLC-5 Food Processor
Broken Switch on West Bend High Performance food processor
We had this problem to but we were able to assemble with the help of a rubber band that held the switch on until the lid was locked in. Then you could use it the same way...pushing the rubber band down to engage the switch. I need to add though that since using this option...for nearly three months, The switch housing broke as well. I am now on the search for something to replace it I guess.
Nov 09, 2008 | West Bend 6526 Food Processor
Instruction Manual for Food Processor
i emailled breville uk yesterday morning about instruction manual for my awt fp3 and had a reply from them just after lunchtime, giving me a downloadable copy of manual
Nov 01, 2008 | Food Processors
Food Processors Logo
142 people viewed this question
Top Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Food Processor Expert? Answer questions, earn points and help others
