Question about Frigidaire Ovens
My Frigidaire oven modelREG-94BK the timer won't stop buzzing
Posted by Kerinna Kennedy on
1 Related Answer
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Posted on Nov 13, 2012
    My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
    According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
    According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
    Dado
    Sep 08, 2015 | Electrolux Ovens
    Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
    F1 button won't stop buzzing
    dis connect board wait three minutes and try agin, if still happens, get a new board.
    Aug 07, 2012 | Jenn-Air Ovens
    My frigidaire oven wont stop beeping and it has a f9 code
    Hi
    F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
    Daniel
    Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
    My daughter turned the timer but when it got to zero and it buzzed....it never stopped buzzing. It is still buzzing 10 hrs now! What can I do?
    unplug your oven. sounds like you need a new timer. the relay is not releasing . cause the timer wont let it
    Jun 19, 2011 | Kenmore Ovens
    Frigidaire won't stop beeping f1 style
    HI, this is a electronic oven control board failure code.
    Replace this damaged electronic oven control (also called EOC or clock). It has failed.
    Aug 13, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Ovens Logo
    Top Frigidaire Ovens Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    Paul Carew
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
