SOURCE: output path
I take it you're using a form, which is in a forms or templates folder. I usually make PDF's directly from the file (customer quotations for example) that they belong in, so the 'current' path which Acrobat is designed to choose by default is conveniently the location I want the PDF also stored in. Is it possible for you to simply create a shortcut to the desired location in the folder that Acrobat is showing you?
SOURCE: "Error applying transforms. Verify that the specified transform
Run kb404307.exe on affected systems.
Important: You should be logged in as an Administrator in order to use this tool.
SOURCE: How do i verify the directory path where adobe photoshop 7.0 is located
Did you install it with the default settings?
Its in the programs folder in the C: drive where windows is normally installed.
If you have 64 bit windows, then its in the programs files x86 if the adobe program is only 32 bit.
But if the program is 64 bit, it will install to program files directory.
