Fuji Micro Generator FJ6200Ri. Remote Start Generator.
At present, the gasoline engine does not have 24 V, diesel engine has 12 V. The ignition of gasoline engines is different from that of diesel engines. Gasoline engines use spark plugs to ignite combustible mixture air to explode for work, so they do not need high speed. A low-power starter does not have to use 24Vstarter battery, while a diesel engine needs a high speed to do its work through a high-pressure spontaneous combustion explosion, such as the excessive volume of a 12V high-power motor. Therefore, the low temperature starting performance of 24V.12V diesel engine is generally used in low power diesel engine, and the application of deceleration starter solves this shortcoming.
SOURCE: Generator won't start & now starter will not shut off when it has power
I'm assuming the key ignition switch has been replaced with a new one. If this didn't correct the problem then the problem could be in the STARTER RELAY stuck in the 'on' position, or in the STARTER SOLENOID switch (located on the starter motor ) stuck in the 'on' position.
The STARTER RELAY should be located around or in a POWER DISTRIBUTION BOX . After locating the STARTER RELAY and gaining access to it, try hooking your charger or jumper cables, whatever way you want to power the battery to make the starter turn over, then while the motor is turning over then pull the STARTER RELAY out and see if that stops it from turning.
If it does then the STARTER RELAY is probably at fault and needs to be relaced. It the motor continues to turn over then the problem is more than likely the STARTER SOLENOID sticking in the 'on' position, and will need to be replaced. That should take care of the starter problem.
Next will be the 'not starting problem'. That could be fuel delivery, spark plugs, coil or ignition control unit. Would be so much more helpful to include date and make of an appliance when seeking help.
SOURCE: I have a Onan Pro 4000E generator with an electric
12v, U1 lawnmower type battery is what I have in mine.
SOURCE: 1962 CHEVROLET TRUCK with points
If/How long will it crank over before it stops? Are you saying it will crank over, but very slow? Has it been sitting quite a while. Got good spark, and fuel?
SOURCE: Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
SOURCE: 2009 SIERRA 1500 WITH FACTORY
Check signal down to the starter. If the signal is present,replace the starter.
