Question about Uniworld Food Mixers
Uniworld 30 Qt mixer. Will only run when we hold in the green / on button. We replaced the button (on/green) but the problem didn't resolve.
3 Related Answers
Anonymous
  • 53 Answers
SOURCE: Kitchenaid 6 qt mixer repair
A small screwdriver or needle nose pliers will work to remove the cir-clips that hold on the shaft.
Posted on May 31, 2010
Fixit Fox
  • 5 Answers
SOURCE: I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
http://www.chefscatalog.com/product/25686-kitchenaid-3qt-stainless-bowl-and-whip-set.aspx
Posted on Jan 14, 2015
Mister Danger
  • 5631 Answers
SOURCE: I have a Uniworld UPM-20E commercial mixer. I bought used from another baker and it was working when I bought it.
Electric devices get damaged sometimes by internal corrosion even if you don't use them. If you have the technical knowledge, take apart the control board or control panel, probably you've got some contact problem. you might be able repair it by cleaning or maybe you might need some part to replace.
If you don't have real knowledge repairing this kind of an appliance, my best advice: take it to a repair service.
Some time ago I tried to do a similar job with my home mixer and had to take pieces in a shoebox to a repair service ; I took it apart, cleaned contacts bur couldn't assemble it againbecause after taking it apat, couldn't assemble it again
Posted on Aug 20, 2015
Aug 20, 2015 | Uniworld UPM-20E 20QT Commercial Planetary...
Where can I get the grease for my Kitchen aid stand mixer?
The grease is food grade grease and Kitchen Aid supply it as a spare part so depending on where you live either from themselves or an Authorised Service Agent. If you are in New Zealand then I can supply.
Jan 01, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
How do I find someone who can supply me with Uniworld mixer parts.
By the time you get these, postage and shipping etc, you may as well buy a cheaper handmixer.
Dec 07, 2014 | Uniworld UPM-30E 30 Quart Mixer With Guard...
Can I Have a wireing diagram for Uniworld m20e year 2012
hi, can i have a wire diagram for a M20E please i changed the contractor but still not working i guess misplace some wire?
thank you
Aug 18, 2014 | Uniworld Foodservice Equipment Upm-M20e...
Mixer does not turn on.
Still have the problem with this mixer not turning on? LEt me know if you have checked the breaker and the cord (Check for a loose or disconnected plug end -- Should have the 3 Prong ground attached. This is often the case, but then the 2nd problem is that one of the SAFETY Switches is not engaged, not allowing the mixer to be turned on -- it's a matter of checking each of these symptoms systematically to know for sure. Let me know if I can help.
Nov 30, 2013 | Uniworld UPM10E Stand Mixer
Missing the bowl raising handle
Check your manual that came with it. There's usually a customer service number. Things like that usually must be ordered dirctly from the manufacturer.
Jan 01, 2013 | Uniworld Commercial Kitchen Mixer 20 Quart
Apr 24, 2010 | KitchenAid KP2671 Professional 6 Series...
Have a d330 Hobart mixer was wondering if I can upgrade to a 40 qt bowl and accessories for this mixer, and if is possible, and if will do the job.been tell that I can do this upgrade but not sure thank...
one would assume that if you get a 40 qt. bowl. you will most likely increase your batch size, correct, i would make do with what you have, that mixer was designed for a 30 qt. bowl, not a 40, hence the d 340 model, but the choice is yours. i would stay with what you have, monomoy
Feb 04, 2010 | Food Mixers
Will hobart 20qt hook fix on a blakeslee 20 qt mixer.
as long as the shafts are the same o.d.and the bayonet pin are the same diminsions you should be ok
Dec 09, 2009 | Blakeslee F-30-CA Stand Mixer
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
Food Mixers Logo
136 people viewed this question
Top Uniworld Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you an Uniworld Food Mixer Expert? Answer questions, earn points and help others
