Http://www.unlockandreset.com/rca-tablets-all-models-hard-reset-instructions
Two methods, but save data to computer before using:
Method 1:
Home screen-->Menu keys-->Settings-->Privacy-->Factory data reset-->Uncheck SD Erase-->touch Reset Phone-->touch Erase Everything
Method 2:
With tablet off, press and hold volume up-->With volume up held, press power button--> Release buttons when RCA appears-->When Android bot appears, press and hold both power button and volume up button-->When menu appears, use volume up and down to navigate to wipe data-->Press the power button-->Use volume up and down to navigate to Yes delete user data-->use power button to select that-->Press power button-->Upon reboot and seeing Welcome, choose your options-->Press Start when finished
SOURCE: forgto password, cannot get in
Hello Gloria,
The only way to regain control of the tablet, since you have forgotten the password is to reset it and start again.
The following was copied from the manual about your tablet; How to Reset; Press to reset the tablet (then press and hold the Power button for 4~5 seconds to turn on the unit).
You may read and download the entire manual here; https://rcaav.com/wp-content/uploads/2016/09/RCT6513W87DK-ebook_En-25-07-2016.pdf
I hope this helps!
Good Luck!
Rich Lilja
You perform a hard reset which restores the device to factory settings and erases the data accumulated since it came out of the box.
How to Reset an RCA Tablet
If it is locked with a pin code, you might want to contact the person you got it from and have them do this.
