Question about FoodSaver Food Saver 11In X 16Ft Roll
My food saver 370 vacuum suction is weak, as evidenced by the food saver bag does not totally evacuate. I've got the bottom panel off. The vacuum pump seems to be functioning. What should I check?
Posted by Ben Cook on
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
My vacmaster pro 160 does not seal bags
Try with a different bag ( I have the same problem, the bags are not the same) if still not working, the you have faulty pump
Mar 14, 2013 | Ary Vacmaster Pro 160 Food Saver 87640
No Suction
i about to say that's always a clog of some sort that causes that
Jan 31, 2013 | Miele S7210 Bagged Upright Vacuum
My Rival food saver does not vacuum air out
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
Apr 19, 2010 | Vacuums
I have a BS 36. Have just changed bag for first time and now the hose part doeasnt have any suction. In fact, the overall suction seems very weak. What can i do?? Helen
I have sorted it! Managed to take the long hose part off and it was full of dust and totally blocked! Cleared it out and now it's as good as new!
Dec 12, 2009 | Sebo Vacuums
The suction on the Kirby Ultimate g is very weak
you probably have a small leak somewhere. it doesn't take much to lose suction. make sure everything is sealed between the vac and bag and make sure there's not a small hole in the bag. the impeller should be alright unless, you've vacuumed up something very hard like a small
coin or something.if the impeller becomes cracked , it will have to be replaced.
Aug 19, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
What is vaccum packing?
Vacuum packing is a method of storing food and presenting it for sale. Appropriate types of food are stored in an airless environment, usually in an air-tight pack or bottle to prevent the growth of microorganisms. The vacuum environment removes atmospheric oxygen, protecting the food from spoiling by limiting the growth of aerobic bacteria or fungi, and preventing the evaporation of volatile components. Vacuum packing is commonly used for long-term storage of dry foods such as cereals, nuts, cured meats, cheese, smoked fish, coffee, and crisps and also for shorter-term storage of fresh foods such as vegetables, meats, and liquids such as soups.
Vacuum packing is also used to reduce greatly the bulk of non-food items. For example, clothing and bedding can be stored in bags evacuated with a domestic vacuum cleaner or a dedicated vacuum sealer. This technique is sometimes used to compact household waste, for example where a charge is made for each full bag collected.
Please rate this fixya
Jan 29, 2009 | Vacuums
My Miele vacuum full bag indicator
Check the suction at the vac, without the hose, if it is strong, then you hose is clogged. If it is weak, filters could be the problem, one is the back where the bag sits, the other is on the top, you can see it when you raise the lid.
Dec 07, 2007 | Vacuums
FoodSaver Food Saver 11In X 16Ft Roll Logo
95 people viewed this question
Top FoodSaver Vacuums Experts
ray gallant
Larry Ng
Larry Ng
Lawrence Oravetz
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
